Intel® MPI Library
2301 Discussions
OpenMP Segmentation Fault on XE Max GPU
lamb
I am trying to find the cause of a segmentation fault when running several of the SPEC Accel OpenMP benchmarks. Specifically, I have been working with the 552.ep (embarrassingly parallel) benchmark.
OS: x86_64 GNU/Linux
CPU: Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
Accelerator: Intel Iris Xe MAX
Toolkit: Intel(R) oneAPI DPC++ Compiler 2021.1.2 (2020.10.0.1214)
Compilation commands:
$ ulimit -s unlimited
$ export IGC_EnableDPEmulation=1
$ export OverrideDefaultFP64Settings=1
$ source /opt/intel/oneapi/setvars.sh
$ icx -g -Wall -O3 -I. -fiopenmp -fopenmp-targets=spir64 *.c -o ep -lm
$ gdb ./ep
Here is the result of running gdb (run). I can install the missing debuginfos and update the question if that would help in finding a solution. I can include the backtrace (gdb bt) also if that would be helpful.
(gdb) run
Starting program: /552.pep/src/ep
Missing separate debuginfos, use: yum debuginfo-install glibc-2.28-127.el8.x86_64
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
warning: Loadable section ".note.gnu.property" outside of ELF segments
[New Thread 0x155550008700 (LWP 811436)]
[New Thread 0x15554d9ac700 (LWP 811437)]
 Reading from input file ep.input
 NAS Parallel Benchmarks (NPB3.3-OPENMP-C) - EP Benchmark
 Number of random numbers generated:        67108864
Thread 1 "ep" received signal SIGSEGV, Segmentation fault.
0x000015553f455bca in vISA::G4_SrcRegRegion::computeLeftBound() () from /lib64/libigc.so.1
Missing separate debuginfos, use: yum debuginfo-install ...
Also, I'm intending to use the level0 backend, but I see "OpenCLProgramContext" in the gdb output. Does this mean I may be using the OpenCL backend by mistake?
Thank you!
AbhishekD_Intel
We can see that you have posted the same thread on the Intel oneAPI HPC Toolkit forum, so will no longer monitor this thread as it's a duplicate.
Please expect the reply on the other thread, link:
https://community.intel.com/t5/Intel-oneAPI-HPC-Toolkit/OpenMP-Segmentation-Fault-on-XE-Max-GPU/m-p/1269309#M8002
Warm REgards,
Abhishek
