Intel® MPI Library
2301 Discussions
Starting a Windows GUI Application with mpiexec
Ricardo_L_
I am trying to launch a windows GUI application which itself spawns one or more mpi applications.
The intention is to form an inter-communicator that allows the spawned mpi processes to communicate with the Window GUI application (as mpi rank 0 within the shared communicator).
The processes are started and they seem to be running, but the GUI does not show.
Is there a solution to this or an alternate method recommended?
Klaus-Dieter_O_Intel
Launching a GUI application under Intel MPI on Microsoft Windows* requires the flags "-localroot" or "-localonly". A simple check with non-MPI programs is:
mpiexec[.spmd] -localroot -np 1 notepad.exe : -n 4 hostname
mpiexec -localonly -np 1 notepad.exe : -n 4 hostname
Please notice the help information from "mpiexec -help".
The flags are described at https://software.intel.com/en-us/node/528868
The full MPI documentation (also in PDF) is available at https://software.intel.com/en-us/articles/intel-mpi-library-documentation.
