Intel® MPI Library
2301 Discussions
Statically linking Intel MP Linpack on Linux: multiple definition of symbols 'free' and 'realloc'
Grigory_R_Intel
Hello!
I am trying to compile Intel MP Linpack from source code with some external libraries on Linux x86_64 (Debian 5.0.8). I use recent MKL set, latest Intel MPI library and latest Intel Compiler. In order to work properly the final binary should be made static (I want some flavour of PIN-based tool to be incorporated into the binary)
I am currently encountering the following problem at final linking:
mpiicc -DAdd__ -DF77_INTEGER=int -DStringSunStyle -DASYOUGO -DHYBRID -I/home/user/linpack_10.3.3/benchmarks/mp_linpack/include -I/home/user/linpack_10.3.3/benchmarks/mp_linpack/include/intel64 -I/opt/intel/composerxe-2011.3.174/mkl/include -I/opt/intel/impi/4.0.1.007/include64 -I/opt/intel/composerxe-2011.3.174/mkl/include -O3 -w -ansi-alias -i-static -z noexecstack -openmp -nocompchk -openmp -mt_mpi -i-static -z noexecstack -static_mpi -nocompchk -u CarbonStartSim -u CarbonStopSim -L/home/user/mit-carbon-Graphite-52bf5d5/lib -L/home/user/mit-carbon-Graphite-52bf5d5/os-services-25032-gcc.4.0.0-linux-ia32_intel64/intel64 -L/home/user/mit-carbon-Graphite-52bf5d5/contrib/orion -pthread -lcarbon_sim -lorion -los-services -lboost_filesystem-mt -lboost_system-mt -pthread -lstdc++ -lm -static -o /home/user/linpack_10.3.3/benchmarks/mp_linpack/bin/intel64/xhpl HPL_pddriver.o HPL_pdinfo.o HPL_pdtest.o /home/user/linpack_10.3.3/benchmarks/mp_linpack/lib/intel64/libhpl.a -L/opt/intel/composerxe-2011.3.174/mkl/lib/intel64 /opt/intel/composerxe-2011.3.174/mkl/lib/intel64/libmkl_intel_lp64.a /opt/intel/composerxe-2011.3.174/mkl/lib/intel64/libmkl_intel_thread.a /opt/intel/composerxe-2011.3.174/mkl/lib/intel64/libmkl_core.a -lpthread /home/user/linpack_10.3.3/benchmarks/mp_linpack/lib_hybrid/intel64/libhpl_hybrid.a /opt/intel/composerxe-2011.3.174/compiler/lib/intel64/libiomp5.a
/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib64/libc.a(malloc.o): In function `free':
(.text+0x2700): multiple definition of `free'
/opt/intel/impi/4.0.1.007/intel64/lib/libmpi_mt.a(i_rtc_hook.o):../../i_rtc_hook.c:(.text+0x0): first defined here
/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib64/libc.a(malloc.o): In function `realloc':
(.text+0x4b10): multiple definition of `realloc'
/opt/intel/impi/4.0.1.007/intel64/lib/libmpi_mt.a(i_rtc_hook.o):../../i_rtc_hook.c:(.text+0x120): first defined here
For some unknown reason Intel MPI has two symbols defined in stock Libc and that breaks linking.
When I remove '-static' flag from linker options everything links fine but I get a binary with shared libs which is not what I need (as instrumentation I am attempting to use is not designed to work with code from shared libraries)
Could anyone tell me how to overcome this problem with symbols?
Thank you!
TimP
Would it not be safer to link libpthread normally (once, at the end, as already set by the -openmp option, so as to follow all libraries creating dependencies)? You can get away with odd linking orders more often with dynamic libraries. I suppose it should not be a problem to link against libiomp5.a and then libiomp5.so, provided that libpthread is searched afterwards only.
Grigory_R_Intel
It seems that adding '--allow-multiple-definition' to linker flags (as the first one - the order is important!) resolved the linking issue. See also Release Notes:
- (SDK only) Certain versions of the GNU* LIBC library define
free()/realloc() symbols as non-weak. Use the --allow-multiple-definition
GNU* linker option to link your application.
I also have been advised that complete static linking of Intel MKL is a bad idea. But at least it is possible to do.
--allow-multiple-definitionTo Subject Sent Size Categories
Derbunovich, Andrey; Kuzmin, Dmitry RE: multiple definition of symbols 'free' and 'realloc' 13:05 23 KB Red Category
Dmitry_K_Intel2
The only thing I'd like to add here is a suggestion to use MKL Link advisor.
