Intel® MPI Library
2288 Discussions
Wrong MPICH_NUMVERSION in mpi.h on Windows?
Volker_J_
we've recently moved to Intel 19 Update 3 MPI and noticed that the MPICH_VERSION macro in mpi.h is wrong/confusing on Windows and is also different than on Linux:
2019.3.203/intel64/include/mpi.h:504 (windows)
#define MPICH_VERSION "0.0"
#define MPICH_NUMVERSION 300
on Linux:
#define MPICH_VERSION "3.3b3"
#define MPICH_NUMVERSION 30300103
The latter case is much more reasonable and works fine, while the first case seems to be broken.
In the end, that 3 digit version number makes PETSc assume that it is using an old MPICH version and therefore compares "0.0" with MPI_Get_library_version(), which will eventually fail on Windows.
https://bitbucket.org/petsc/petsc/src/f03f29e6b9f50a9f9419f7d348de13f7c6b76dec/src/sys/objects/pinit.c#lines-807
Can you please fix the version number of windows?
Thank you and kind regards,
Volker Jacht
Yury_K_Intel
Thank you for the report, it will be fixed in upcoming release.
Best regards, Yury
