I cannot figure out why the following basic code does not compile...
PROGRAM TEST_MPI_ILP64
USE MPI, ONLY : MPI_SEND
IMPLICIT NONE (TYPE, EXTERNAL)
END PROGRAM TEST_MPI_ILP64
I get the following message:
- error #6580: Name in only-list does not exist or is not accessible. [MPI_SEND]
The program is compiled on Windows, with the "Intel® Fortran Compiler 2024.0.2 [Intel(R) 64]" compiler.
The path to the mpi.mod file is provided as "$(ONEAPI_ROOT)\2024.0\include\mpi\ilp64 " where ONEAPI_ROOT is defined by the script oneapi-vars.bat and has the value "C:\Program Files (x86)\Intel\oneAPI".
The two following compiler options are used: /integer-size:64 and /real-size:64
The output section of the build log is reproduced below.
Compiling with Intel® Fortran Compiler 2024.0.2 [Intel(R) 64]...
ifx /nologo /debug:full /Od /I"C:\Program Files (x86)\Intel\oneAPI\2024.0\include\mpi\ilp64" /warn:interfaces /integer-size:64 /real-size:64 /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc170.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,"C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Tools\MSVC\14.36.32532\bin\HostX64\x64" /Qm64 "C:\Users\XXXXXX\Desktop\TEST_MPI_ILP64\TEST_MPI_ILP64.F90"
C:\Users\XXXXXX\Desktop\TEST_MPI_ILP64\TEST_MPI_ILP64.F90(2): error #6580: Name in only-list does not exist or is not accessible. [MPI_SEND]
compilation aborted for C:\Users\XXXXXX\Desktop\TEST_MPI_ILP64\TEST_MPI_ILP64.F90 (code 1)
TEST_MPI_ILP64 - 2 error(s), 0 warning(s)
What am I overlooking?
Please note, for the time being we will not support ILP64 mode in MPI_F08.
However, we might reconsider this decision if more customers will request this feature.
Thanks for posting in the Intel forums.
We are working on it and will get back to you soon.
Thanks & Regards
Shivani
We are able to reproduce the issue at our end. We are working on it and will get back to you soon.
Thanks & Regards
Shivani
currently we do not support ILP64 in our MPI_F08 module. For large counts we advise to use MPI 4.0 standard 'large counts' which is available in MPI_F08.
However, I am collecting customer requests for ILP64 support in MPI_F08, if there is a critical mass we may reconsider supporting ILP64.
Why do you want to use ILP64 instead of large counts with MPI_F08?
Best
Tobias
![](/skins/images/06022F5BB6D2F28C8F102671A0F06E85/responsive_peak/images/icon_anonymous_message.png)
