Intel® MPI Library
2255 Discussions
amplxe: Error: Ftrace is already in use.
psing51
i am trying to run vtune amplifier 2019 to collect system-overview as -
export NPROCS=36
export OMP_NUM_THREADS=1
mpirun -genv OMP_NUM_THREADS $OMP_NUM_THREADS -np $NPROCS  amplxe-cl -collect system-overview  -result-dir /home/puneet/run_node02_impi2019_profiler_systemoverview/profiles/attempt1_p${NPROCS}_t${OMP_NUM_THREADS}  -quiet $INSTALL_ROOT/main/wrf.exe
I had collected hpc-performance data without any issue. Afterwards , i ran aforementioned command but had to kill it (result dir was incorrect.). when i re-ran the amplxe-cl, i am getting following error messages -
amplxe: Error: Ftrace is already in use. Make sure to stop previous collection first.
I have tried deleting the /home/puneet/run_node02_impi2019_profiler_systemoverview/profiles/* and i have also rebooted the node.
even then those error messages are showing up.
Please advice.
psing51
i have posted the issue in vtune forum - https://software.intel.com/en-us/forums/intel-vtune-amplifier/topic/806844
I am unable to find options for deleting this topic/post from here
