Intel® MPI Library
mpirun -n 1 IMB-MPI1 error
wanghw
I use the rc_verbs and ud_verbs of UCX as transport layer S of OFI, and I get the following error when I run the following command.
./mpirun -n 1 IMB-MPI1
Here's what I'm talking about.
./fi_info -l
./ucx_info -d | grep Transport
export  info:
UCX_TLS=rc_verbs,ud_verbs
Does anyone know how to deal with this error?
 Thanks & Regards
AishwaryaCV_Intel
Thank you for posting in intel communities.
Could you please let us know the following details , so that we can reproduce the issue at our end:
1. Which command did you use to set FI_PROVIDER as "UCX" or by default FI_PROVIDER was "ucx"?
2. OS,CPU and Hardware details
Thanks And Regards,
Aishwarya
wanghw
Thanks for the reply.
1.I use command is "export FI_PROVIDER=ucx".
2.I isn't using a real hardware platform, currently simulating hardware behavior using soft.
Other information is shown in the figure below:
Thanks & Regards
AishwaryaCV_Intel
From the screenshot of cat /proc/version output, we are able to see that , you are using unsupported version of Red Hat(4.5), please update to the supported version of Intel MPI.
Please find the system requirements of Intel MPI:
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/mpi-library-system-requirements.html
From the screenshot of lscpu output , we are able to see that , its not intel processor and we don't provide support other than Intel products so could you please try to run with Intel Processors?
Please find the supported Intel Processors here: https://www.intel.in/content/www/in/en/support/products/873/processors.html#122139
Thanks And Regards,
Aishwarya
wanghw
 I'm Sorry. My environment does not allow me to replace systems and hardware.
So I solved my problem by adapting the open Fabric Inter.
However, I think that doing so will result in a reduction in the characteristics of its own optimization.
Thanks & Regards
AishwaryaCV_Intel
Glad to know that your issue got resolved.
As your initial query is resolved , if you are facing any further issues , please post a new question as this thread will no longer be monitored by Intel.
Thanks And Regards,
Aishwarya
