Intel® MPI Library
mpirun -ppn option does not work.
ccopemem
We use OneAPI on IBM Spectrum LSF environment.
Now we are facing that "mpirun -np 2 -ppn 1 ./mpi-program.out" does not work.
It always run all processes on same node.
LSF support said it is not related LSF.
What does it caused by ?
And how do we investigate this issue ?
TobiasK
@ccopemem can you please provide the output of I_MPI_DEBUG=10 and I_MPI_HYDRA_DEBUG=1?
ccopemem
Hi TobiasK,
Thank you for your reply and big hint.
I got this output with I_MPI_DEBUG=10 and I_MPI_HYDRA_DEBUG=1.
Both I_MPI_JOB_RESPECT_PROCESS_PLACEMENT and ppn = 1 specified, defaulting to scheduler-supplied value.
-ppn worked fine by specified I_MPI_JOB_RESPECT_PROCESS_PLACEMENT=disable.
We appreciate for your kind support.
TobiasK
@ccopemem
I don't see any logs, but I guess this is solved now?
ccopemem
Hi TobiasK,
Thank you for your following.
Yes, it is solved.
We appreciate your kindly support and big hint.
