Intel® Makers
9867 Discussions
İntel Galileo ya başlangıç!!!
iYILD2
merhaba arkadaşlar elinizde türkçe kaynak varmı veya example olan bri dosaya varmı galileo ya başlarken yardımcı olabilecek?
Carlos_M_Intel
Hi ilhanyildiz,
The documentation for Galileo is located in: https://www-ssl.intel.com/content/www/us/en/do-it-yourself/support/maker/galileo/galileo-documents-a... Intel® Galileo Board Hardware Support
If you are getting started with this board, I suggest you to follow the steps in https://software.intel.com/en-us/iot/library/galileo-getting-started IoT - Intel® Galileo Board Get Started Guide | Intel® Developer Zone
Remember to upgrade the firmware of the board by following http://downloadmirror.intel.com/24748/eng/IntelGalileoFirmwareUpdaterUserGuide-1.0.4.pdf the firmware Updater Tool
Charlie
Carlos_M_Intel
Hi ilhanyildiz,
Charlie
