Intel® Makers
9881 Discussions
总是扫描不出来,无法更新
衡王000
疯雷000
我也是这样,你解决了吗?​
Luis_at_Intel
Hi @疯雷000​ ,
Thanks for reaching out. It looks like you are trying to use the Intel(R) Driver Update & Support Assistant (Intel® DSA) to update your Intel(R) Edison, is that correct? The Intel® DSA is not meant to update your Intel(R) Edison board, you may have to download the drivers and firmware manually and install the drivers and update the firmware manually. You can find the available downloads for your board here.
Let me know if you have additional questions.
Luis
