Hi all, I soldered a PCF8574AT serial converter on a 1602A lcd display and connected it to my Edison module with Arduino Breakout board.
The backlight turns on as expected. Using i2cdetect I can find the chip address at 0x3f:
Now I try to run this simple code in Eclipse:
# include "lcm1602.h"
# include
# include "mraa.hpp"
int main() {
upm::Lcm1602* lcd = new upm::Lcm1602(6, 0x3f);
lcd->setCursor(1,1);
lcd->write("Hello World");
sleep(5);
delete lcd;
return 0;
But nothing is displayed. Both methods setCursor and write get mraa::SUCCESS ar result.
Using bus 0,1, and 6 or a random address in the Lcm1602 constructor changes nothing.
Same result if I connect the module to A4 and A5 pins or to SCL and SDA pins on the breakout board.
Setting the cursor in (0,0), (2,2), etc. doesn't help.
Any thoughts?
Today I gave it another try, but the device seemed to be disappeared from the i2c bus:
At that moment I was enabling the i2c bus using these commands:
echo 27 > /sys/class/gpio/export
echo 28 > /sys/class/gpio/export
echo mode1 > /sys/kernel/debug/gpio_debug/gpio27/current_pinmux
echo mode1 > /sys/kernel/debug/gpio_debug/gpio28/current_pinmux
But while googling for a fix, I found here http://www.emutexlabs.com/project/215-intel-edison-gpio-pin-multiplexing-guide http://www.emutexlabs.com/project/215-intel-edison-gpio-pin-multiplexing-guide that these commands should be used:
echo 204 > /sys/class/gpio/export
echo 205 > /sys/class/gpio/export
echo 236 > /sys/class/gpio/export
echo 237 > /sys/class/gpio/export
echo 14 > /sys/class/gpio/export
echo 165 > /sys/class/gpio/export
echo 212 > /sys/class/gpio/export
echo 213 > /sys/class/gpio/export
echo 214 > /sys/class/gpio/export
echo low > /sys/class/gpio/gpio214/direction
echo low > /sys/class/gpio/gpio204/direction
echo low > /sys/class/gpio/gpio205/direction
echo in > /sys/class/gpio/gpio14/direction
echo in > /sys/class/gpio/gpio165/direction
echo low > /sys/class/gpio/gpio236/direction
echo low > /sys/class/gpio/gpio237/direction
echo in > /sys/class/gpio/gpio212/direction
echo in > /sys/class/gpio/gpio213/direction
echo high > /sys/class/gpio/gpio214/direction
...And voilà the device came back on the i2c bus 6.
Then I rewrote my project in Java:
public class JavaTest {
static {
try {
System.loadLibrary("javaupm_i2clcd");
} catch (UnsatisfiedLinkError e) {
System.err.println("error in loading native library");
System.exit(-1);
public static void main(String[] args) throws InterruptedException {
upm_i2clcd.Lcm1602 lcd = new upm_i2clcd.Lcm1602(0, 0x3f);
lcd.setCursor(0, 0);
lcd.write("Hello World!");
And... magically it worked!
Still have to realize what I did to have it working, but I'm leaving it here for someone else like me to find it.
static {
try {
System.exit(-1);
