Intel® Makers
9867 Discussions
ADC_inputvoltage
ptada
Hi, I m using intel quark d2000, for adc if i apply the voltage from the board(D2000 board) it giving correct digital value but if i give the analog value from outside power supply then it is showing incorrect digital value.i am using this program .
* Copyright (c) 2015, Intel Corporation
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of the Intel Corporation nor the names of its
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE INTEL CORPORATION OR CONTRIBUTORS BE
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
# include "qm_adc.h"
# include "qm_interrupt.h"
# include "qm_scss.h"
# include "qm_pinmux.h"
/* QMSI ADC app example
# define NUM_CHANNELS (2)
# define NUM_SAMPLES_POLLED (10)
# define NUM_SAMPLES_INTERRUPT (50)
int main(void)
# if (QUARK_D2000)
int i;
qm_adc_config_t cfg;
qm_adc_xfer_t xfer;
qm_adc_channel_t channels[] = {QM_ADC_CH_8, QM_ADC_CH_9};
uint32_t samples_polled[NUM_SAMPLES_POLLED] = {0};
QM_PUTS("\nADC example app start");
/* Enable the ADC and set the clock divisor */
clk_periph_enable(CLK_PERIPH_CLK | CLK_PERIPH_ADC |CLK_PERIPH_ADC_REGISTER);
clk_adc_set_div(100); /* ADC clock is 320KHz @ 32MHz */
/* Set up pinmux */
qm_pmux_select(QM_PIN_ID_8, QM_PMUX_FN_1);
qm_pmux_select(QM_PIN_ID_9, QM_PMUX_FN_1);
qm_pmux_input_en(QM_PIN_ID_8, true);
qm_pmux_input_en(QM_PIN_ID_9, true);
/* Set the mode and calibrate */
qm_adc_set_mode(QM_ADC_0, QM_ADC_MODE_NORM_CAL);
qm_adc_calibrate(QM_ADC_0);
/* Set up config */
cfg.window = 2; /* Clock cycles between the start of each sample */
cfg.resolution = QM_ADC_RES_12_BITS;
qm_adc_set_config(QM_ADC_0, &cfg);
* ADC polled mode example
QM_PUTS("ADC polled mode");
/* Set up xfer */
xfer.ch = channels;
xfer.ch_len = NUM_CHANNELS;
xfer.samples = samples_polled;
xfer.samples_len = NUM_SAMPLES_POLLED;
/* Run the conversion */
if (qm_adc_convert(QM_ADC_0, &xfer))
QM_PUTS("ERROR: qm_adc_convert failed");
return 1;
/* Print the values of the samples */
for (i = 0; i < NUM_SAMPLES_POLLED; i++)
QM_PRINTF("%d:%d ", i, (unsigned int)samples_polled[i]);
QM_PUTS("\n\rADC example app complete");
# endif /* QUARK_D2000 */
return 0;
Pablo_M_Intel
Hi mailto:pavankumartadas1989@gmail.com pavankumartadas1989@gmail.com,
Thank you for contacting us.
So the ADC is giving different output values even though you're providing the same input on the same port? First, I'd check that the signal given from the board and the one from the external power supply are exactly the same. Could you post a picture of the output of the readings of the oscilloscope on both these signals?
We'll be waiting for your response.
-Pablo
Sergio_A_Intel
Do you still need assistance with this thread? Did you check our latest suggestion?
-Sergio
