I tryed connecting an ADS1115 at i2c 1 and 0x48.
var mraa = require('mraa');
var version = mraa.getVersion();
if (version >= 'v0.6.1') {
console.log('mraa version (' + version + ') ok');
else {
console.log('mraa version(' + version + ') is old - this code may not work');
var ADS1X15 = require('jsupm_ads1x15');
var ads1115 = new ADS1X15.ADS1115(1, 0x48);
//var ads1015 = new ADS1X15.ADS1015(1, 0x48);
setInterval(function(){
console.log(ads1115.getSample());
//console.log(ads1015.getSample());
console.log("*********************");
}, 1000);
but only get an error:
mraa version (v0.9.0) ok
ERROR: module.js:340
ERROR: throw err;
ERROR: Error: Cannot find module 'jsupm_ads1x15'
at Function.Module._resolveFilename (module.js:338:15)
at Function.Module._load (module.js:280:25)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object. (/home/root/.node_app_slot/main.js:11:15)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
Hi KimLorentz
On Edison image version 159.devkit you will need to update UPM and MRAA libraries by editing the /etc/opkg/iotkit.conf file. You can run the following command.
root@edison:~# echo "src iotkit http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586 http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586" > /etc/opkg/iotkit.conf
The run the following commands
root@edison:~# opkg update
root@edison:~# opkg install mraa
root@edison:~# opkg install upm
After this, download the code from: https://github.com/intel-iot-devkit/upm/blob/master/examples/javascript/ads1x15.js upm/ads1x15.js at master · intel-iot-devkit/upm · GitHub and run it with node ads1x15.js
Charlie
Hi KimLorentz
Charlie
Dont get any errors anymore, tnx.
Console,log settings
console.log(ads1115.getGain());
console.log(ads1115.getSPS());
console.log(ads1115.getCompMode());
console.log(ads1115.getCompPol());
console.log(ads1115.getCompLatch());
console.log(ads1115.getCompQue());
console.log(ads1115.getContinuous());
console.log(ads1115.getThresh());
Console.log respons
0
1024
128
false
false
true
3
false
-2.0479376316070557
How do I write to the ADS1115?
Hi KimLorentz,
Take a look in: https://github.com/intel-iot-devkit/upm/blob/master/src/ads1x15/ads1x15.h upm/ads1x15.h at master · intel-iot-devkit/upm · GitHub you will see the available functions that the library has. Check for the set* functions like setGain and setSPS I think this will help you.
Charlie
Tryed using the set function but dont know how to do that.
Do you know?
else {
// Instantiate on I2C bus
ads1115.setGain(); // Set to 2.048 (GAIN_TWO)
ads1115.setSPS(); // Set to 128 SPS
console.log("Sample: " + ads1115.getSample()); // Read DIFF 0-1
console.log("Gain: " + ads1115.getGain());
console.log("SPS: " + ads1115.getSPS());
}, 100);
Hi KimLorentz
I don't have your shield to test this so I'm getting error messages after trying to run different codes because the UPM library verifies if the shield is indeed connected to the board.
On your code, you are using ads1115, the ads1115.h offers the SPS constants you can use:
SPS_8 = ADS1115_DR_8SPS,
SPS_16 = ADS1115_DR_16SPS,
SPS_32 = ADS1115_DR_32SPS,
SPS_64 = ADS1115_DR_64SPS,
SPS_128 = ADS1115_DR_128SPS,
SPS_250 = ADS1115_DR_250SPS,
SPS_475 = ADS1115_DR_475SPS,
SPS_860 = ADS1115_DR_860SPS
In your case you have to use SPS_128, or you can try with the HEX value: 0x0080
In the ads1x15.h you will find the constants for the gains.
GAIN_TWOTHIRDS = ADS1X15_PGA_6_144V,
GAIN_ONE = ADS1X15_PGA_4_096V,
GAIN_TWO = ADS1X15_PGA_2_048V,
GAIN_FOUR = ADS1X15_PGA_1_024V,
GAIN_EIGHT = ADS1X15_PGA_0_512V,
GAIN_SIXTEEN = ADS1X15_PGA_0_256V
Try with GAIN_TWO or with the HEX value: 0x0400
Let me know your results.
Charlie
Thayed that, only get funny responds.
how do I manualy write data to the i2c device without the library to se how that goes
Hi KimLorentz,
I apologize for the delay in my response, I would like to know if you have been able to work on this and if you have some new results.
Regarding your question:
Check the following commands in order to interact from the Linux prompt:
http://linux.die.net/man/8/i2cdetect i2cdetect(8): detect I2C chips - Linux man page
http://linux.die.net/man/8/i2cdump i2cdump(8): examine I2C registers - Linux man page
http://linux.die.net/man/8/i2cset i2cset(8): set I2C registers - Linux man page
http://linux.die.net/man/8/i2cget i2cget(8): read from I2C/SMBus chip registers - Linux man page
Charlie
Hi, I am trying to run the code in the original post. I have installed both mraa v1.0.0 and upm v0.7.0. When I run the code I get the error:
mraa version (v1.0.0) ok
/home/root/node/adc.js:12
Error: Illegal arguments for construction of _exports_ADS1115
at Error (native)
at Object. (/home/root/node/adc.js:12:15)
at Module._compile (module.js:409:26)
at Object.Module._extensions..js (module.js:416:10)
at Module.load (module.js:343:32)
at Function.Module._load (module.js:300:12)
at Function.Module.runMain (module.js:441:10)
at startup (node.js:139:18)
at node.js:968:3
Any ideas as to what is causing this issue? Could it be a versioning issue with upm?
Thanks, Curtis
Edit: It was a problem with my pull up resistors, it works now.
