Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor I
ALSA programming in edison
Jump to solution
I am trying to do alsa programming in edison. I am trying to run this example which appears to handle two channel data (left channel and right channel audio).
http://www.alsa-project.org/alsa-doc/alsa-lib/_2test_2latency_8c-example.html http://www.alsa-project.org/alsa-doc/alsa-lib/_2test_2latency_8c-example.html
but I get an error saying
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Arduino: 1.6.5 (Windows 8), Board: "Intel® Edison"
test_mraa_on_eidisson.ino.ino:15:34: fatal error: ../include/asoundlib.h: No such file or directory
compilation terminated.
Error compiling.
So how can I do alsa programming in edison?
Accepted Solutions
Highlighted
Where are you putting this code, directly in the Arduino IDE? The error you get is because there are libraries missing so you can't compile the code. I'd suggest using C from the Linux terminal and try to compile from there. How are you compiling the code, directly from the IDE? If you see the same error look if you have the library included, if not, you can look for it and include it.
Take a look at these links, they contain useful information
https://trac.ffmpeg.org/wiki/Capture/ALSA https://trac.ffmpeg.org/wiki/Capture/ALSA
http://www.tldp.org/HOWTO/Alsa-sound-3.html Alsa-sound-mini-HOWTO: Before you start
http://alsa.opensrc.org/Quick_Install alsa.opensrc.org
Let me know your results.
Sergio
Highlighted
Sergio
Highlighted
Solved.
Highlighted
Hello Segey,
I am using the W8731 as mentioned in this page of yours:
http://www.malinov.com/Home/sergey-s-blog/inteledisonandopenmusiclabsaudiocodecshield http://www.malinov.com/Home/sergey-s-blog/inteledisonandopenmusiclabsaudiocodecshield
But when I give i2cset I get this error
codecset.sh: 105: codecset.sh: i2cset: not found
codecset.sh: 108: codecset.sh: i2cset: not found
codecset.sh: 111: codecset.sh: i2cset: not found
codecset.sh: 114: codecset.sh: i2cset: not found
codecset.sh: 117: codecset.sh: i2cset: not found
codecset.sh: 123: codecset.sh: i2cset: not found
codecset.sh: 127: codecset.sh: i2cset: not found
codecset.sh: 130: codecset.sh: i2cset: not found
How shall I solve this error.
Highlighted
Solved. I2c-tools were supposed to be installed but how shall I configure the name of the codec and how shall I use it?
Sergey's page says this but I do not understand what software documentation he is referring to
*********************************************************Using the Audio Device
The codec is connected to ALSA device hw:1,0 . Refer to the software documentation on configuring the device name. For example in mpg123 player the audio device can be specified using -a switch:
mpg123 -a hw:1,0 -v "Dave Brubeck - Take Five.mp3"
Highlighted
I did everything and did i2cset for the code shield but when I type "aplay -l" I think the device is not getting listed.Here is the output of 'aplay -l'
root@ubilinux:/home/edison/mraa/examples# sh codecset.sh
root@ubilinux:/home/edison/mraa/examples# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 8/8
Subdevice # 0: subdevice # 0
Subdevice # 1: subdevice # 1
Subdevice # 2: subdevice # 2
Subdevice # 3: subdevice # 3
Subdevice # 4: subdevice # 4
Subdevice # 5: subdevice # 5
Subdevice # 6: subdevice # 6
Subdevice # 7: subdevice # 7
card 0: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 8/8
What shall I do? Could you please post the output of aplay -l sergey.
Highlighted
I get a write error saying "Write failed" when I try to configure the codec shield and some times I get resource busy error. What shall I do?
Highlighted
What image are you using, the standard Yocto image or the IoT image?
Sergio
Highlighted
I am using Ubilinux. Should I roll back to yocto?
Highlighted
The supported image is the Yocto image. If you need support using the Ubilinux image you can contact http://www.emutexlabs.com/forum/index EmutexLabs . They will provide a more accurate response.
Sergio
Highlighted
I did a roll back to Yocto. Now when in Ubilinux I did this
apt-get install alsa-base libasound2 libasound2-dev alsa-tools alsa-utils
but not when I say
opkg install alsa-base libasound2 libasound2-dev alsa-tools alsa-utils
It says cannot install package alsa-base
Highlighted
There is no package in AlexT's repo called alsa-base. Take a look at the alsa packages available in http://repo.opkg.net/edison/repo/ Index of /edison/repo .
Sergio
