Community
cancel
Showing results for
Search instead for
Did you mean:
KSels
New Contributor II
AM2315 and JavaScript
I got the AM2315 to work without library in arduino, I only need to make it work on javascript.
Can anyone help me there.
Here is my current arduino code.
# define AM2315_I2CADDR 0x5C
# define AM2315_READREG 0x03
# include
float humidity, temp;
void setup()
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(115200); // start serial for output
delay(100);
void readData()
uint8_t reply[10];
// Wake up the sensor
Wire.beginTransmission(AM2315_I2CADDR);
delay(2);
Wire.endTransmission();
// OK lets ready!
Wire.write(AM2315_READREG);
Wire.write(0x00); // start at address 0x0
Wire.write(4); // request 4 bytes data
delay(10); // add delay between request and actual read!
Wire.requestFrom(AM2315_I2CADDR, 8);
for (uint8_t i=0; i<8; i++) {
reply[i] = Wire.read();
//Serial.println(reply[i], HEX);
humidity = reply[2];
humidity *= 256;
humidity += reply[3];
humidity /= 10;
Serial.print("Humidity: "); Serial.println(humidity);
temp = reply[4] & 0x7F;
temp *= 256;
temp += reply[5];
temp /= 10;
Serial.print("Temp: "); Serial.println(temp);
void loop()
readData();
delay(5000);
Tags (1)
Community Manager
Hello KimLorentz,
I suggest you to try using mraa. This library can control I2C and it has several examples ( https://github.com/intel-iot-devkit/mraa/blob/master/examples/javascript/bmp85.js and https://github.com/intel-iot-devkit/mraa/blob/master/examples/javascript/rgblcd.js) and documentation ( http://iotdk.intel.com/docs/master/mraa/node/classes/i2c.html) that will be of much help for you when trying to "translate" your script to JavaScript.
I hope this information helps you.
-Peter.
