Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
About Inti joule's spi
Jump to solution
I'd like to use spi with marr,
The following error occurs.
>>> import mraa
>>> mraa.getVersion()
'v1.1.2'
>>> spi = mraa.Spi(0)
Traceback (most recent call last):
File "", line 1, in
File "/usr/lib/python2.7/site-packages/mraa.py", line 1504, in __init__
this = _mraa.new_Spi(*args)
ValueError: Error initialising SPI bus
Please tell me how to deal with it.
Where can I find out how to use spi?
Community Manager
Hi Osakana,
I would love to help you with that, I think you should update your MRAA library first (the latest is v1.5.1). To do this you can follow the next link: https://software.intel.com/en-us/updating-libraries-for-joule.
After I updated the library I ran the example code in the MRAA repository without problems ( https://github.com/intel-iot-devkit/mraa/blob/master/examples/python/spi.py) and I added the line "print (m.getVersion())" to see the version that I'm using.
I hope you find this information useful.
Have a nice day.
-Leonardo
Community Manager
Hi Osakana,
Have a nice day.
-Leonardo
Community Manager
Hi Leonardo,
Thank you for your reply.
curl https://raw.githubusercontent.com/intel-iot-devkit/joule-code-samples/master/mraa-install.sh https://raw.githubusercontent.com/intel-iot-devkit/joule-code-samples/master/mraa-install.sh | sh
Installation succeeded!
The error disappeared.
I tried the example code next.
As a result, "We have an error captain!" Is displayed.
Is this correct?
It is an additional question,
How to switch SPI0 or SPI1?
m.Spi (0)、 m.Spi (1) Is it?
Please tell me.
Community Manager
Hi Osakana,
Yes, the example gave that line to me too, at least it initialized the SPI without problems.
You can use m.Spi (1) too, there shouldn't be issues with it. If you need more information about Python and MRAA, I suggest you to check the API: http://iotdk.intel.com/docs/master/mraa/python/mraa.html# spi
I hope you find this useful.
Have a nice weekend.
-Leonardo
Community Manager
Hi Leonardo,
Thanks for the reply again.
It is in the same state.
So is SPI still in the preparation stage?
Community Manager
Hi Osakana,
What do you mean with "It is in the same state"? And about the last question, can you explain it to me?
I will be waiting for your reply.
-Leonardo
Community Manager
Hi Leonardo,
I'm sorry.
The result you tried is the same as the result I tried.
Is SPI usable commonly?
Community Manager
Hi Osakana,
There shouldn't be problems using the SPI, in the example you are getting the message "We have an error captain!", because you have to connect MISO to MOSI on your board, it is commented on the code.
In case that you are going to use Spi(0), you have to connect J12Pin2 to J12Pin4, if you use Spi(1) you have to connect J13Pin29 to J13Pin27. If you do this in the example you won't get the error message.
-Leonardo
Community Manager
Hi Leonardo,
Thanks for the reply.
>"We have an error >captain!", because you have to connect MISO to MOSI on your board,
I am convinced
I want to light the LED of dotestar (APA 102).
I am referring to Edison's sample, but it does not work properly.
https://github.com/smoyerman/EdisonDotStar https://github.com/smoyerman/EdisonDotStar
Please give me some hints.
Community Manager
Hi Osakana,
I'm not sure why this doesn't work, and I don't have a DotStart to try it.
At least the example ran without error messages, and I don't think it is a SPI issue. So I recommend you to try to contact the author of the example to help you more.
Have a nice day.
-Leonardo
