Community
cancel
Showing results for
Search instead for
Did you mean:
YTaka13
About LSM9DS1
Jump to solution
I try to get sensor datas of LSM9DS1 connected to the Edison(Ubilinux)
But I could not find a source code except Arduino.
Ubilinux can not use Arduino IDE, so I could not get sensor datas.
Is there someone who have used LSM9DS1?
Please tell me a source code to get sensor data.
The Upm(https://github.com/intel-iot-devkit/upm intel-iot-devkit/upm · GitHub) had only been uploaeded "LSM9DS0"(not LSM9DS1)
Thank you for reading.
Diego_V_Intel
Hello ytaka,
Both, the LSM9DS0 and the LSM9DS1, include accelerometer, gyroscope and magnetometer. I'm not aware about the differences between both ICs, but they might work very similar. My recommendation for you is to check their datasheets to know how they work. If they work in a similar way, you might be able to adapt a code originally for the LSM9DS0 to be used with the LSM9DS1. The differences might be in the registers used.
An example code for the LSM9DS0 can be checked in the following site: http://iotdk.intel.com/docs/master/upm/classupm_1_1_l_s_m9_d_s0.html upm: LSM9DS0 Class Reference. The datasheets for each IC can be checked in the following links:
Diego.
Diego_V_Intel
Hello ytaka,
Diego.
