Intel® Makers
9868 Discussions
About the Quantization of Sensors
JZhan591
Dear All,
Do you guys know how to quantization the sensor?For example, The data which the temperature sensor gives me is a three-digit numbers ,but I need the real temperature(℉) .I have
temperature air quality gas sensor(MQ5) moisture sensor.Do you guys know some references or manual about the quantization between them?
Thanks a lot!!
Community Manager
Hi Jingwei,
I'm not sure what you are trying to achieve, but the following document about quantization might be helpful for you: https://www.princeton.edu/~cuff/ele201/kulkarni_text/digitizn.pdf Sampling and Quantization. If this is not what you are looking for, please explain in detail what you want to achieve.
Diego
Community Manager
Hi Jingwei,
Diego
