Intel® Makers
9881 Discussions
About the detail size of galileo gen2 board
LWei4
Hi, I wanna build a box to galileo gen2 board, to make a packaging. Now the problem is I can't figure out the detail size of it, like the relative location of every component. Is there any one can help me, very appreciate.
Diego_V_Intel
Hello LouisWei,
I'm afraid that if you want to know the location of every component and the board's dimensions, you would have to take the measurements by yourself. There aren't documents that specify neither the exact board's dimensions nor the relative location of the components. The only document available that might be of help is the following: http://www.intel.com/support/galileo/sb/CS-035440.htm Intel® Galileo Gen 2 Board — Design Files. In that document you will find the design files of Galileo Gen2, but you must use the Allegro software to open them.
Diego.
Diego_V_Intel
Hello LouisWei,
Diego.
LWei4
Thx, very appreciate your answer. I will take some measuring.
