Intel® Makers
9867 Discussions
Accessing GPIO without sysfs
JJosé1
Hello everyone, this is my first post on this forum, but i'm look to be a active user, so i hope it won't be the last
So, i'm executing programs on Galileo Gen 2 executing them directly using ssh. I see that topic bellow about achieve better timings to interact with the GPIO of the Galileo, but is available only cross-compiling through the Arduino IDE.
So when i'm doing my research, i found this other topic
about building this features in libmraa, but in this case is for Edison. And i didn't understand well in the topic ( i'm not from a country with english as a native language ) if this feature was been added to the master branch or not. After that, my questions are : The MRAA lib have features for fast GPIO accessing? if yes, how can i use it? if not, have anyone already did this and can share some information or even a library ? (Can be in any language, but is preferred to be in C++)
Please help me to achieve this performance with Galileo D:
Thanks in advance!
Community Manager
I looked for some information about fastGPIO on the Galileo but none of it was related to MRAA.
Some of the most useful links I found are
http://www.emutexlabs.com/13-projects/203-getting-started-with-intel-galileo-gen-2 http://www.emutexlabs.com/13-projects/203-getting-started-with-intel-galileo-gen-2
http://allynh.com/blog/intel-galileo-getting-to-grips-with-gpio-speeds/ http://allynh.com/blog/intel-galileo-getting-to-grips-with-gpio-speeds/
That discuss the speeds, code and performance of the pins. I found in this link http://iotdk.intel.com/docs/master/mraa/namespacemraa.html http://iotdk.intel.com/docs/master/mraa/namespacemraa.html an option of pinMode called PIN_FAST_GPIO. I haven't tested this with the Galileo but give it a try and let us know if you found this useful.
-Sergio
JJosé1
Hi Sergio! First thanks for reply!!
But have some way to do GPIO access directly without using the arduino IDE ? Or some material that can help me to understand create by myself some library for fast gpio running directly on Linux? The performance links I already saw but i don't know how to do it in a C/C++ program, for example.
Btw, the first link is broken D:
Again, Thanks!
Community Manager
You can access GPIOs directly from Linux. In /sys/class/gpio you can find the gpios available and can configure a variety of options. You can see more information here https://anandvetcha.wordpress.com/2014/09/28/galileo-gen2-gpio-control-using-linux/ https://anandvetcha.wordpress.com/2014/09/28/galileo-gen2-gpio-control-using-linux/
I didn't find any information on how to do fastgpio without the use of the IDE. What speeds are to attempting to reach using the fastgpio method?
-Sergio
Community Manager
Do you still need help with this thread? Were you able to access the GPIOs without the IDE?
-Sergio
