Intel® Makers
9881 Discussions
Adafruit VL53L0X TOF Sensor
DDavi52
Hi:
I am attempting to connect the Adafruit vl53l0x sensor to an Intel Edison Arduino development board with no success. The steps I've taken are:
1. Connect the v53l0x sensor to the a Arduino Uno board, download library and confirmed the sensor operates correctly. This performed correctly.
2. Connect the v53l0x sensor to the Intel Edison board. The sensor is the only connected device. The sensor is connected to the +5V from the development board. This is the same connection as on the Arduino Uno board.
3. Reboot the Intel Edison board - simply to be certain that the unit is clean.
4. Perform a "i2cdetect -y -r 6" to confirm the sensor is visible to the Edison board. The sensor is not reported.
Any suggestions would be appreciated.
Community Manager
Hello David.H,
Thanks for reaching out!
What is happening is that the sensor is not detected because the I2C bus has not been set up yet. When using the I2C bus manually on Linux, you also have to manually set it up, you can do so with the following script:
# !/bin/sh
echo 28 > /sys/class/gpio/export
echo 27 > /sys/class/gpio/export
echo 204 > /sys/class/gpio/export
echo 205 > /sys/class/gpio/export
echo 236 > /sys/class/gpio/export
echo 237 > /sys/class/gpio/export
echo 14 > /sys/class/gpio/export
echo 165 > /sys/class/gpio/export
echo 212 > /sys/class/gpio/export
echo 213 > /sys/class/gpio/export
echo 214 > /sys/class/gpio/export
echo low > /sys/class/gpio/gpio214/direction
echo high > /sys/class/gpio/gpio204/direction
echo high > /sys/class/gpio/gpio205/direction
echo in > /sys/class/gpio/gpio14/direction
echo in > /sys/class/gpio/gpio165/direction
echo low > /sys/class/gpio/gpio236/direction
echo low > /sys/class/gpio/gpio237/direction
echo in > /sys/class/gpio/gpio212/direction
echo in > /sys/class/gpio/gpio213/direction
echo mode1 > /sys/kernel/debug/gpio_debug/gpio28/current_pinmux
echo mode1 > /sys/kernel/debug/gpio_debug/gpio27/current_pinmux
echo high > /sys/class/gpio/gpio214/direction
After running this script, try the i2cdetect command again and let us know how it goes.
I hope this information helps you,
Pedro M.
Community Manager
Hello David.H,
# !/bin/sh
Pedro M.
