Intel® Makers
9868 Discussions
Adding Recipies / Layer to ref-os-iot
PHand1
Good evening,
I have successfully pulled & built the most recent ref-iot-source, using bitbake, from https://github.com/01org/ref-os-iot GitHub - 01org/ref-os-iot: This is the official distribution of the Intel(R) Reference Operating System for the Internet…
I would like to know how I can add a recipie / layer to my build, as the Joule does not come with the packages I need with the default image. I am looking for IW, tcpdump, and a few others. I have attempted to follow the guide outlined here: https://wiki.yoctoproject.org/wiki/Cookbook:Example:Adding_packages_to_your_OS_image https://wiki.yoctoproject.org/wiki/Cookbook:Example:Adding_packages_to_your_OS_image , but I cannot seem to locate the ../machine/local.conf file in order to add the recipie. Would you happen to know what file I would add the necessary recipies to, or provide an example for how I would add IW? I plan to pull the recipes from here: http://layers.openembedded.org/layerindex/branch/master/layers/ OpenEmbedded Layer Index - layers
Thank you as always.
-Peter
PHand1
I have figured out which files to edit:
~/work/ref-os-iot/meta-ref-os-iot/conf/layer.conf
add the following line to the bottom: CORE_IMAGE_EXTRA_INSTALL += ""
eg( CORE_IMAGE_EXTRA_INSTALL += "iw")
Nagivate to and open the following file in a text editor: ~/work/ref-os-iot/meta-ref-os-iot/conf/distro/ref-os-iot.conf
Find the line that says "SUPPORTED_RECIPIES_CHECK = "warn" and uncomment it (ie, remove the # )
Community Manager
Hi PeterHand,
Thanks for your interest in the Intel® Joule™ Platform.
I'm glad to know that you figure out which files to edit! Please let us know if you have any more questions, we will be happy to help.
Have a nice day!
-Jose P.
