Intel® Makers
9873 Discussions
Affected Arduino Libraries
OGonz1
Hi there,
I was wondering if someone knows which Arduino libraries get affected by using Arduino Galileo. I am particularly interested in those that rely on SPI/I2C communications (not shield libraries) like for example those used for IMU and GPS.
Specifically, I want to know if this ones would work....
https://github.com/adafruit/Adafruit_GPS GitHub - adafruit/Adafruit_GPS: An interrupt-based GPS library for no-parsing-required use
https://learn.adafruit.com/adafruit-ultimate-gps/arduino-wiring https://learn.adafruit.com/adafruit-ultimate-gps/arduino-wiring
https://learn.adafruit.com/adafruit-10-dof-imu-breakout-lsm303-l3gd20-bmp180/software https://learn.adafruit.com/adafruit-10-dof-imu-breakout-lsm303-l3gd20-bmp180/software
Thanks in advance.
FTinetti
Honored Contributor I
Hi Oscar,
I'm not sure about the specific hardware you are asking for, but there is a list of "Supported Arduino libraries" in the .pdf at http://www.intel.la/content/www/xl/es/embedded/products/galileo/galileo-sw-release-notes.html http://www.intel.la/content/www/xl/es/embedded/products/galileo/galileo-sw-release-notes.html
HTH,
Fernando.
Pablo_M_Intel
Hi OscarGonzalez,
Along with Fernando's contribution, I would also suggest you to check the Shield report for the Edison and Galileo boards. There are examples of various devices that make use of different Arduino libraries and that are connected via SPI and I2C.
Here's the link: http://www.intel.com/content/dam/support/us/en/documents/Galileo-Edison_ShieldTestReport_330937-002.... http://www.intel.com/content/dam/support/us/en/documents/Galileo-Edison_ShieldTestReport_330937-002.....
Pablo
