Intel® Makers
9881 Discussions
After synchronizing libraries in Eclipse, apps fail with libmraa.so.0 not found
AStoe1
Apps that previously worked fine no longer run after Eclipse prompted me to synchronize libraries with the Edison. Now I get this error when they run:
error while loading shared libraries: libmraa.so.0: cannot open shared object file: No such file or directory
I've been trying to find a solution for this for 2 days. I can run the blinking led example fine but anything that requires lower level tools like the LCD give me this error. Does anyone have any advice? I will be very hesitant to upgrade libraries in the future.
AStoe1
Here is some more diagnostics from another thread, I just ran:
ldd tled
ldd tled
linux-gate.so.1 (0xb777c000)
libmraa.so.1 => /usr/lib/libmraa.so.1 (0xb7744000)
libupm-ppd42ns.so.0 => /usr/lib/libupm-ppd42ns.so.0 (0xb7741000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x42577000)
libm.so.6 => /lib/libm.so.6 (0x42342000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x42561000)
libc.so.6 => /lib/libc.so.6 (0x421bc000)
libpthread.so.0 => /lib/libpthread.so.0 (0x42325000)
librt.so.1 => /lib/librt.so.1 (0x423ac000)
/lib/ld-linux.so.2 (0x4218f000)
libmraa.so.0 => not found
root@andrew:/tmp# ls -l /usr/lib | grep mraa
lrwxrwxrwx 1 root root 12 May 2 17:55 libmraa.so -> libmraa.so.1
lrwxrwxrwx 1 root root 16 May 2 17:55 libmraa.so.1 -> libmraa.so.1.0.0
-rwxr-xr-x 1 root 2222 186084 Apr 28 15:06 libmraa.so.1.0.0
-rwxr-xr-x 1 root 2222 136054 Apr 28 15:06 libmraajava.so
root@andrew:/tmp# opkg files libmraa0
opkg files libmraa0
Collected errors:
* opkg_files_cmd: Package libmraa0 not installed.
root@andrew:/tmp#
AStoe1
I also tried this:
>> opkg install libmraa0
Unknown package 'libmraa0'.
Collected errors:
* opkg_install_cmd: Cannot install package libmraa0.
Community Manager
Hi Andrew,
Which Eclipse version are you using? Go to Help > About Eclipse Platform
Which image are you using on your board? Run the command uname -a, with the latest image you should receive Linux edison 3.10.17-poky-edison+ # 2 SMP PREEMPT Mon Mar 14 15:26:16 PDT 2016 i686 GNU/Linux
The problem seems to be that the board has old versions of MRAA and UPM, run the commands:
echo "src mraa-upm http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586 http://iotdk.intel.com/repos/3.0/intelgalactic/opkg/i586" > /etc/opkg/mraa-upm.conf opkg update opkg install mraa opkg install upm
Charlie
AStoe1
Hi Charlie,
I'm using the Intel Eclipse version. But the issue appears unrelated to Eclipse. I also updated everything again on the board itself using opkg but the issue remained, and I found an open issue on the mraa github repo where others are also having this problem, and it is an upstream error on the upm repo. The solution is to symlink libmraa.so.0 to libmraa.so.1 and this solved all problems and my apps started running again.
Community Manager
I'm glad to know that you were able to solve this, and your apps are running again
Charlie
