Intel® Makers
9880 Discussions
After upgrading to Windows 10 version 10586 Stick is dead
AFerr13
After upgrading to Windows 10 version 10586 the Stick not worked properly, I tried restoring but it wasn't possible , I updated the bios didn't work , I tried restoring from Bios but now the key is dead!
blue LED turns off after 10 seconds ant turn off.
SA# H69761-103
S/N GEFC51800QYT
IUman
In this case if you Intel® Compute Stick do not work anymore after trying to upgrade to Windows 10 you can submit an online service request to get a warranty replacement here:
http://www.intel.com/p/en_US/support/contactsupport Contact Support
Please be aware that to upgrade the ICS to Windows 10 it is required to update Windows 8.1 first with all the updates available even the optional ones and it is required to have a BIOS version later than 0024 be starting the upgrade.
You can see some information about this issue here:
/thread/92126?start=45&tstart=0 https://communities.intel.com/thread/92126?start=45&tstart=0
AKriz
As for the requirement for 8.1 to have all updates and BIOS 0024+ that's not true. The ICS will go from base 8.1 out of packet to Windows 10 10240 without a BIOS update or 8.1 patched. Your false claim and requirement is in relation to Windows 10 10586.0 and doesn't even help with that installation.
I'm concerned that Intel are purposely giving out wrong requirements to counter some of their liability.
AFerr13
The key is dead! blue LED turns off after 10 seconds ant turn off.
IUman
Hi Auferrari,
In this case if your Intel® Compute is not working at all after trying to upgrade to Windows 10, please submit a warranty replacement at the following link:
Thanks for your patience with this issue
AFerr13
Thanks , I will require the replacement , I Another key Themselves and blocked after upgrading to Windows 10 version 10586
SA # H69761-103
S / N GEFC51901GB3
Now I'm stuck in Other Updates
