Community
cancel
Showing results for
Search instead for
Did you mean:
AMont11
Anaconda Installation Error
Hi all,
On one of my Edison boards, I am able to install Anaconda and use it with no problem(Did this a while back). I am starting new with another board and I try to the install anaconda but the following errors are outputted :
[/home/root/anaconda2] >>>
PREFIX=/home/root/anaconda2
installing: _cache-0.0-py27_x0 ...
installing: python-2.7.11-0 ...
tar: bin/python: Cannot create symlink to 'python2.7': Operation not permitted
tar: bin/python2: Cannot create symlink to 'python2.7': Operation not permitted
tar: lib/libpython2.7.so: Cannot create symlink to 'libpython2.7.so.1.0': Operation not permitted
tar: lib/pkgconfig/python.pc: Cannot create symlink to 'python-2.7.pc': Operation not permitted
tar: lib/pkgconfig/python2.pc: Cannot create symlink to 'python-2.7.pc': Operation not permitted
tar: share/man/man1/python.1: Cannot create symlink to 'python2.7.1': Operation not permitted
tar: share/man/man1/python2.1: Cannot create symlink to 'python2.7.1': Operation not permitted
tar: Exiting with failure status due to previous errors
root@edison:~#
I don't understand why ? There must be something that I installed before but I can't seem to remember if I did anything different before..
Carlos_M_Intel
Hi Admir,
Are you sure you are installing the same version? Are you using the root account or are you using another one?
Let's try with the following:
Delete the /home/root/anaconda2 folder
Set the base-feeds.conf file with http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html Edison Package Repo Configuration Instructions
Run opkg update
Run opkg install tar
Run opkg install tar-dev
Run wget https://3230d63b5fc54e62148e-c95ac804525aac4b6dba79b00b39d1d3.ssl.cf1.rackcdn.com/Anaconda2-2.5.0-Li... https://3230d63b5fc54e62148e-c95ac804525aac4b6dba79b00b39d1d3.ssl.cf1.rackcdn.com/Anaconda2-2.5.0-Li...
Run bash Anaconda2-2.5.0-Linux-x86.sh
The script will ask you to accept the license, enter yes, and do not change the prefix, if you are installing it at /usr you may have problems. If you press enter and accept the directory where is going to be installed you shouldn't have problems. Also, you need to be sure to have enough space on the board to download and extract all the required files.
Charlie
AMont11
Hi I tried the same exact thing you mentioned to do but I am getting the same error output as before:
AMont11
I believe the problem lies with tar, I try to use tar with other downloads and this is what I get :
root@edison:~# tar xvfJ tar-1.28.tar.xz
tar (child): xz: Cannot exec: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
I am trying to see if I can install a newer version of tar. Because when i look in the anaconda shell script file the error occurs where tar is called with a condition that the tar on the edison does not have.
Admir
AMont11
So that didn't work.
Carlos_M_Intel
Hi Admir,
I would like to replicate the error message you are obtaining so I would like to know more information in order to reproduce it.
Which image version are you using right now? Run configure_edison --version (I'm using the 159.devkit version)
Which other changes have you done? Did you install something else?
After running opkg install tar and opkg install tar-dev, did the installation was successful or did you receive an error message?
What is the output of cat /etc/opkg/base-feeds.conf?
Charlie
AMont11
hi CMata_Intel,
I do have the 159 version.I didn't make any changes. I did install both tar and tar-dev. no error when i install it.
root@edison:~# opkg install tar
Package tar (1.27.1-r0) installed in root is up to date.
root@edison:~# opkg install tar-dev
Package tar-dev (1.27.1-r0) installed in root is up to date.
root@edison:~# configure_edison --upgrade
The latest version is already installed.
root@edison:~# cat /etc/opkg/base-feeds.conf
src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all
src/gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison
src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32
Carlos_M_Intel
Hi Admir,
I wasn't able to replicate the issue you have, I tried with images 146, 159 and 159.devkit,I received errors if I don't install tar and tar-dev but once I installed those packages I didn't have problems.
I would like to know if you have been able to work on this. If you still have problems with this, please check the packages you have installed, the conflict could be with one of those but if you are using a clean image I suggest you to flash the board and start again.
Charlie
AMont11
Hi CMata_Intel,
So I figured out what the problem was, it was the format of the sd card which I mounted home on. I was able to reformat to ext4 and tar was then able to create the symlinks created by the Anaconda.
Thanks for trying to hep out.
Appreciate it,
Admir M.
