Intel® Makers
9867 Discussions
AnalogWrite in Eclipse Workspace
COkon
I want to know how to write this on the eclipse work-space of the Intel Edison
analogWrite(3, 127);
Thanks in Advance
Diego_V_Intel
Hi dunex_1,
The analogWrite() method is used to generate a PWM wave. You could use the MRAA libraries to accomplish this in C/C++. I recommend you to check the following example which shows how to use the PWM with MRAA: https://github.com/intel-iot-devkit/mraa/blob/master/examples/c%2B%2B/Pwm3-cycle.cpp mraa/Pwm3-cycle.cpp at master · intel-iot-devkit/mraa · GitHub
In the following site there is additional documentation about PWM with MRAA: http://iotdk.intel.com/docs/master/mraa/classmraa_1_1_pwm.html mraa: Pwm Class Reference
Diego
Diego_V_Intel
Hi dunex_1,
Diego
COkon
Hi Diego,
But the pwm pin uses floating numbers in percentage. I want to be able to pass a value of 0 to 255 instead of a duty cycle of 0.0 to 1.0
Diego_V_Intel
Hi dunex_1,
You could use the map() function to make the conversion from 0-255 to 0.0-1.0. The map() function is easy to program, the description of how it works can be checked in the following site: https://www.arduino.cc/en/Reference/Map Arduino - Map
Diego
COkon
Hi @ DiegoV_Intel
Thank you for directing me to the path. I have improved my code. Can you look at this thread and reply to it too with any suggestion please!
Thanks in advance!
