Intel® Makers
9881 Discussions
Any Repo for sshfs?
NAves
Is there an existing repo which would allow for sshfs-fuse installation through opkg?
Cheers,
Pablo_M_Intel
Hi Nastooh,
I'm not aware of any available repo to install sshfs-fuse using opkg. However, according to an older ( ) post it should it be possible to build sshfs with the openembedded sshfs-fuse recipe, which you can found here http://layers.openembedded.org/layerindex/recipe/5748/ http://layers.openembedded.org/layerindex/recipe/5748/. If you're not able to find the opkg package, try with this other method.
Pablo
Pablo_M_Intel
Hi Nastooh,
Pablo
