Community
cancel
Showing results for
Search instead for
Did you mean:
RAtlu1
New Contributor II
Any way to edit and generate env files manually? [edison.env,target.env]
Jump to solution
Dear All,
Is there a way I can only compile the following files and convert them to Bin files? I wanted to edit them and change a few environment variables. I really dont want use saveenv by going into each edison i buy in the command prompt.
http://git.yoctoproject.org/cgit/cgit.cgi/meta-intel-edison/tree/meta-intel-edison-bsp/recipes-bsp/u... meta-intel-edison - Layer for the Intel Edison Development Platform
edison.env
target.env
Thanking you
Community Manager
Hi Mosfet,
Thank you for your patience. All the details are available in the Yocto layer meta-intel-edison-bsp under the recipes-bsp in the package u-boot. The recipe files with .bb extension has the do_compile and do_install functions which shows how the build is done. Also, check the .inc files which has the details for python script for do_build_mkimage_tool. You may extract the necessary code from those files to create your own independent build.
-Pablo
Community Manager
Hi Mosfet,
We are now investigating your case. As soon as we have an answer we will let you know. Thank you for your patience.
Pablo
RAtlu1
New Contributor II
Dear Pablo
I am thinking this is how it is.
  1. xFSTK writes "_dnx_fwr.bin" and "_dnx_osr.bin" IFWI images and after that recovery starts
  2. xFSTK sends u-boot.img (OSIP+MBR, GPT, u-boot and env 0 and 1) and "real" ifwi
  3. IFWI reboots and reloads from flash copy
  4. u-boot.bin is written with its environment variables.
The thing is, we already have the vmlinuz, initramfs and a new distro (that only runs from memory and thus prevents any kind of crashes etc for edison). The only thing lacking is if we can somehow just only change the environment files instead of compiling the entire yocto.
You can if it can be more modular for compilation, separate u-boot.bin with its own env files that we can compile separately and u-boot.img with its env that can compile separately.
RAtlu1
New Contributor II
that way, say for example we can edit or define our own partition scheme in u-boot and recompile them as and when needed while developing OSes.
RAtlu1
New Contributor II
offset size label purpose0x00000000 1MB - OSIP + MBR + GPT0x00100000 2MB u-boot0 First U-Boot0x00300000 1MB u-boot-env0 First U-Boot environment variables0x00400000 2MB u-boot1 Second U-Boot (not populated by Yocto)0x00600000 1MB u-boot-env1 Second U-Boot environment variables0x00700000 1MB factory Edison factory data (FAT)0x00800000 24MB panic ???0x02000000 32MB boot Kernel partition (FAT)0x04000000 512MB rootfs Root filesystem (ext4)0x24000000 768MB update OTA (FAT)0x54000000 2752MB home User filesystem (ext4)
# U-Boot.img on eMMC in LBA (LBA size: 512 bytes) # | description | OSII | GPT label # 0x000000 - 0x000001 | MBR + OSIP | - | - # 0x000001 - 0x000022 | GPT | - | - # 0x000022 - 0x000800 | padding with 0 (alignment) | - | - # 0x000800 - 0x001800 | u-boot0 | 1 | u-boot0 # 0x001800 - 0x002600 | primary environment | - | u-boot-env0<span style="font-size: 10.666666666666666px; font...
Community Manager
Hi Mosfet,
-Pablo
