Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9882 Discussions
Anyone successfully build Release 2.1 with PREEMPT_RT patch?
GGan5
So far I only successfully applied the PREEMPT_RT patch on Release 1.6 which was released years ago. Just wondering could anyone share their experience for applying similar patch on the current Release 2.1? I'm still pondering upon the build failure since the kernel version is the same though.
Community Manager
Which are the source files you are using? Are you using the patch from these files or are you getting it from another place?
Which kernel version are you getting and which is the one you want to get?
Please let us know if you are having other errors while building the image.
Charlie
Community Manager
I would like to know if you have been able to work on this. Could you give us more information regarding the files, versions and sources you are using.
Charlie
