Intel® Makers
9868 Discussions
Arduino 1.5.3 IDE Galileo on Mac OSX 10.7.5
RHunt7
Hi
I've just set up my Arduino Galileo on my Mac.
Using the 'Blink' example - it compiles okay, but then fails to upload/transfer.
Error log below.
Any answers?
Robert
Binary sketch size: 49,098 bytes (of a 262,144 byte maximum) - 18% used
starting download script
# !/bin/sh
Args to shell: /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/x86/bin /var/folders/6h/8k0glk896537fzb216fj0xwh0000gn/T/build6333886195766888193.tmp/Blink.cpp.elf COM1
Serial Port PORT (note: should be /dev/cu.xxxxxx for OSX)
echo "starting download script"
Using tty Port COM1
echo "Args to shell:" $*
Sending Command String to move to download if not already in download mode
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: TTY port to use.
# path may contain \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
tty_port_id=$3
echo "Serial Port PORT" $com_port_id "(note: should be /dev/cu.xxxxxx for OSX)"
echo "Using tty Port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch download" > $tty_port_id
# Give the host time to stop the process and wait for download
sleep 1
Deleting existing sketch on target
# Move the existing sketch on target.
echo "Deleting existing sketch on target"
$fixed_path/lsz --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" < $tty_port_id > $tty_port_id
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Transfer incomplete
# $fixed_path/lsz.exe --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" < $tty_port_id > $tty_port 1>&0
# Execute the target download command
# Download the file.
host_file_name=$2
$fixed_path/lsz --escape --binary --overwrite $host_file_name < $tty_port_id > $tty_port_id
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Transfer incomplete
# mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name# */}"
Moving downloaded file to /sketch/sketch.elf on target
echo "Moving downloaded file to /sketch/sketch.elf on target"
$fixed_path/lsz --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" < $tty_port_id > $tty_port_id
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Retry 0: Got ZNAK
Transfer incomplete
Community Manager
Check if the correct port is selected, Tools->Serial Port
You should see a check mark in front of /dev/cu.usbmodemxxxxx where xxxxx is hex number, as example my mac shows /dev/cu.usbmodemfa141.
Community Manager
MPous
Innovator
Hi! i have the same problem but my Serial Port is correctly checked on the Arduino IDE. What can happen?
thanks!
Binary sketch size: 75.907 bytes (of a 10.000.000 byte maximum) - 0% used
# !/bin/sh
Args to shell: /Users/mpous/Downloads/Arduino Edison.app/Contents/Resources/Java/hardware/tools/x86/bin /var/folders/SD/SDgczYLXFXqZHw4DlMP-H++++TM/-Tmp-/build5634497438882380740.tmp/firstv1sion.cpp.elf /dev/cu.usbserial-A102GW1Y
Using tty Port /dev/cu.usbserial-A102GW1Y
path_to_exe=$1
tty_port_id=$3
sleep 1
"$fixed_path/lsz" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" < $tty_port_id > $tty_port_id
Retry 0: Got TIMEOUT
Transfer incomplete
# "$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" < $tty_port_id > $tty_port 1>&0
host_file_name=$2
"$fixed_path/lsz" --escape --binary --overwrite $host_file_name < $tty_port_id > $tty_port_id
Retry 0: Timeout on pathname
Transfer incomplete
"$fixed_path/lsz" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" < $tty_port_id > $tty_port_id
Transfer incomplete
RaadH_Intel
Marc, which usb connection are you using?
-Raad
APist1
Hello everybody, thanks to some friends
It seems that
solved the problem.
An
MPous
Innovator
Hi Raad, i'm using cu/usbserial...
RaadH_Intel
Marc, you are not using the correct device, you should use /dev/cu.usbmodem# d# , where # is a digit 0-9, for example /dev/cu.usbmodem1d113.
SGiff
New Contributor II
I was also bogged down at this point - and in fact the EDI did not see a cu.usbmodem.
The actual issue was a dodgy USB cable - although the cable worked fine on an Arduino Due suspect (cheap chinese cable) that it was a bit dodgy.
Ran blink fine.
Ran the Prime number test which took (from memory 1760 msec) on the Due and it took 11 msec on the Arduino Edison......................
Stan
Community Manager
+1 for dodgy USB cable issues. Too funny. Swapped out my cheap USB cable then it all worked fine. Thanks Stan.
CChar5
On Mac, I noticed the "Edison" partition auto-mounts, so be sure to unmount that drive before uploading new code. Fixed my problem.
