Intel® Makers
9881 Discussions
[Arduino 1.6.4] Board Manager failure
rfenj
Hello all,
I tried to use Arduino IDE from the Windows Intel Edison IDE Installer.
Intel Edison IDE Installer, is installing ARDUINO IDE 1.6.4, without Edison Board Support. So I use the Arduino IDE Board Manager to install Intel Edison Board Support.
Unfortunately it looks like that the git repo defined is no more available :
I got the error below :
The link does not exist any more...
Is it possible to know the new valid URL to add in Board Manager preferences :
Pablo_M_Intel
Hi redafenj,
Are you by any chance connected to a VPN or internalnetwork? Commonly, this issue appears when this type of connection is being used.
If this doesn't solve the issue, you can try downloading the Arduino IDE 1.6.0 which already comes with the Edison and Galileo packages pre-installed, https://downloadcenter.intel.com/download/24355/Intel-Arduino-IDE-1-6-0 https://downloadcenter.intel.com/download/24355/Intel-Arduino-IDE-1-6-0.
PabloM_Intel
rfenj
Hi Pablo,
I do not think this is the problem here. I set correctly the proxy settings in the Arduino IDE. Furthermore the Board Manager is able to download update infos before installing the INTEL Edison.
The URL that the Arduino IDE 1.6.4 is fetching does not exist anymore...
https://github.com/01org/corelibs-edison/ https://github.com/01org/corelibs-edison/ is valid address but https://github.com/01org/corelibs-edison/ https://github.com/01org/corelibs-edison/archive is NOT...
So I already workaround by installing the Arduino IDE 1.6.5 and here no problem.
Could you please by the way give the valid URL Address to locate the INTEL Edison Board package ? so that it can be easily fixed without the need and extra time to re install a new Arduino IDE ?
Reda
Pablo_M_Intel
rfenj
Hi
I used the latest Arduino release and it was working fine.
Thanks for sharing the package.
Reda
