Intel® Makers
9881 Discussions
Arduino 101 : Cannot open DFU device 8087:0aba?
LCros
I recently purchased the Arduino 101 board, and have successfully installed the Arduino IDE (v1.6.7), but am having issues uploading any sketches. When I attempt to upload the Blink sketch, I get the following error:
Sketch uses 29,989 bytes (15%) of program storage space. Maximum is 196,608 bytes.
starting download script
Args to shell: C:\Users\Dad\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.4+1.14/x86/bin C:\Users\Dad\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/Blink.ino.elf COM3 quiet
Serial Port PORT
BIN FILE C:\Users\Dad\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/Blink.ino.bin
Waiting for device...
ERROR: Timed out waiting for Arduino 101.
I have searched a bit online for others having similar issues, and that got me pointed in the direction of the USB drivers. I have tried this on two PC's (Win 10, Win 7, both with only USB2), with the same result. I have also tried two different Arduino 101 boards, same result. As some of the posts suggest, I have tried using the master reset on the Arduino 101 at various times before, during and after the upload, but without success.
I do get a USB disconnect "bong" when I press the master reset, and a USB connect "bong" ~5 seconds later. Attempting to upload a sketch also results in the disconnect/connect events, separated again by ~5 sec. This leads me to believe that there is basic communication between the IDE and Arduino 101, but there are issues with the DFU mode of communication. I do see the "Ports (COM & LPT) / Arduino 101 Serial Monitor (COMx)" device in Device Manager, but have noticed that there is no "libusb (WinUSB) devices / Arduino 101 DFU Interface" in Device Manager in that 5 seconds when the DFU interface should be active. That leads me to think there may be an issue with the USB driver for the libusb/DFU interface.
Has anyone else seen these issues? I am anxious to get on to playing with the IMU on the Arduino 101, but can't seem get out of the gate ...
Sergio_A_Intel
Please post your question in the Arduino 101 forum. You'll get an appropriate response to you inquiry of Arduino 101 here https://forum.arduino.cc/index.php?board=103.0 Arduino 101
Sergio
LCros
I have posted it there as well (http://forum.arduino.cc/index.php?topic=383656.0 Arduino 101 : Cannot open DFU device 8087:0aba). From reading other posts, they seem to be struggling with the issue though, so I thought I would post it here as too.
Here is hoping for a solution ...
LCros
Reading through the posts, it appears as though you can only upload sketches to the Arduino 101 on USB3 :-( I ordered and installed a PCI-E USB3 adapter card in my computer, and am able to upload the BLINK sketch successfully now.
For reference, here is the link to Amazon for the USB3 adapter I used, there are a number of them available though : http://www.amazon.com/gp/product/B00DSXG4YW?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 http://www.amazon.com/gp/product/B00DSXG4YW?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Hopefully a USB2 solution is soon forthcoming.
