Intel® Makers
9874 Discussions
Arduino 101 - can't upload second sketch; could be COM5 vs COM3 enumeration change from Win10 software update
Community Manager
Hello all,
First, is this the right place to ask Arduino 101 (Curie) questions? I didn't see one.
I set up the various software on my Windows 10 desktop system and got the first tutorial I tried to work.
It's this one:
https://www.arduino.cc/en/Tutorial/Genuino101CurieIMUOrientationVisualiser https://www.arduino.cc/en/Tutorial/Genuino101CurieIMUOrientationVisualiser
The USB serial port enumerated as COM5 but after some software updated on my Win10 machine, it enumerated as COM3. I suspect that could have caused the problem I have now.
The sketch I uploaded is still working ok; I have verified a few ways after changing the COM5 references to COM3.
I can't seem to upload a new sketch, however. I'll try again after rebooting my desktop.
But this is what I see now:
Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino 101"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\fred\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\fred\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\fred\Documents\Arduino\libraries" -fqbn=Intel:arc32:arduino_101 -vid-pid=0X8087_0X0AB6 -ide-version=10608 -build-path "C:\Users\fred\AppData\Local\Temp\build92b3094ad731ac8b4bfe1ac0175cb360.tmp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Users\fred\Documents\Arduino101Curie\sketch\sketch_mar24a\sketch_mar24a.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\fred\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\fred\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\fred\Documents\Arduino\libraries" -fqbn=Intel:arc32:arduino_101 -vid-pid=0X8087_0X0AB6 -ide-version=10608 -build-path "C:\Users\fred\AppData\Local\Temp\build92b3094ad731ac8b4bfe1ac0175cb360.tmp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Users\fred\Documents\Arduino101Curie\sketch\sketch_mar24a\sketch_mar24a.ino"
"C:\Users\fred\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.4+1.0/bin/arc-elf32-g++" -c -mARCv2EM -mav2em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10608 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\system/libarc32_arduino101/common" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\system/libarc32_arduino101/drivers" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\system/libarc32_arduino101/bootcode" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\system/libarc32_arduino101/framework/include" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\cores\arduino" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\variants\arduino_101" "C:\Users\fred\AppData\Local\Temp\build92b3094ad731ac8b4bfe1ac0175cb360.tmp\sketch\sketch_mar24a.ino...." -o "nul"
"C:\Users\fred\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.4+1.0/bin/arc-elf32-g++" -c -mARCv2EM -mav2em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10608 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\system/libarc32_arduino101/common" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\system/libarc32_arduino101/drivers" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\system/libarc32_arduino101/bootcode" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\system/libarc32_arduino101/framework/include" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\cores\arduino" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\variants\arduino_101" "-IC:\Users\fred\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\libraries\CurieIMU\src" "C:\Users\fred\AppData\Local\Temp\build92b3094ad731ac8b4bfe1ac0175cb360.tmp\sketch\sketch_mar24a.ino...." -o "nul"
"C:\Users\fred\AppData\Local\Arduino15\packages\Intel\tools\arc-elf32\1.6.4+1.0/bin/arc-elf32-g++" -c -mARCv2EM -mav2em -mlittle-endian -g -Os -Wall -fno-reorder-functions -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-defer-pop -Wno-unused-but-set-variable -Wno-main -ffreestanding -fno-stack-protector -mno-sdata -ffunction-sections -fdata-sections -fsigned-char -fno-rtti -fno-exceptions -D__ARDUINO_ARC__ -std=c++11 -w -x c++ -E -CC -DF_CPU=32000000L -DARDUINO=10608 -DARDUINO_ARC32_TOOLS -DARDUINO_ARCH_ARC32 -D__CPU_ARC__ -DCLOCK_SPEED=32 -DCONFIG_SOC_GPIO_32 -DCONFIG_SOC_GPIO_AON -DINFRA_MULTI_CPU_SUPPORT -DCFW_MULTI_CPU_SUPPORT -DHAS_SHARED_MEM "-IC:\Users\fred\AppData\Local\Arduino15\pac...
Community Manager
Hi fejkerr,
Even though the Arduino 101 board is based on the Curie module, the board itself is supported by Arduino.cc. I recommend you to post your questions in their dedicated forum to the Arduino 101 board; you will receive a better assistance there: https://forum.arduino.cc/index.php?board=103.0 https://forum.arduino.cc/index.php?board=103.0
Diego
Community Manager
Hi fejkerr,
Diego
Community Manager
