Community
cancel
Showing results for
Search instead for
Did you mean:
AKapl3
Arduino-Edison WString Incompatibility
Jump to solution
I'm having a incompatibility issue using the WString.h library. I'm getting errors with the String.c_str() converter command. I was able to add in the necessary commands and fix the problem. I think the Intel Edison WString.h file should be updated with the Arduino WString.h to include missing commands. This way other arduino libraries can compatible.
Accepted Solutions
Diego_V_Intel
Hello AKap,
Thank you for the suggestion. I'll pass it to the appropriate team so they can check it.
On the other hand, some time ago another user had a similar issue: . I know that you were able to fix the problem, but I recommend you to check that thread since there is a workaround that you might find helpful.
Diego.
Diego_V_Intel
Hello AKap,
Diego.
