Community
cancel
Showing results for
Search instead for
Did you mean:
GAlva7
Arduino IDE error on Fedora 23
Jump to solution
I followed this guide https://software.intel.com/en-us/get-started-arduino-install# Linux IoT - Installing the Arduino* IDE | Intel® Developer Zone but when i installed the new boards with the boards manager i get this in console
[root@localhost ~]# /home/lewatoto/arduino-1.6.7/arduino
Picked up JAVA_TOOL_OPTIONS:
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/etc/ld.so.cache links to an absolute path /etc/ld.so.cache
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/ranlib links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-ranlib
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/nm links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-nm
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/strip links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-strip
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/cpp links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-cpp
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/ar links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-ar
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/objcopy links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-objcopy
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/gcc links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-gcc
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/objdump links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-objdump
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/ld links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-ld
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/libexec/i586-poky-linux-uclibc/gcc/i586-poky-linux-uclibc/4.7.2/as links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/i586-poky-linux-uclibc/i586-poky-linux-uclibc-as
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/i586-poky-linux-uclibc/opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/opkg links to an absolute path /opt/clanton-tiny/1.4.4/sysroots/x86_64-pokysdk-linux/usr/bin/opkg-cl
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/i586-poky-linux-uclibc/usr/src/debug/libgcc/4.7.2-r20/build/libgcc/gthr-default.h links to an absolute path /jenkins_builder/workspace/GLLO_1.0.5-Toolchain-Linux64/yocto_build/tmp/work-shared/gcc-4.7.2-r20/gcc-4.7.2/libgcc/gthr-posix.h
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/i586-poky-linux-uclibc/usr/src/debug/libgcc/4.7.2-r20/build/libgcc/unwind.h links to an absolute path /jenkins_builder/workspace/GLLO_1.0.5-Toolchain-Linux64/yocto_build/tmp/work-shared/gcc-4.7.2-r20/gcc-4.7.2/libgcc/unwind-generic.h
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/i586-poky-linux-uclibc/usr/src/debug/libgcc/4.7.2-r20/build/libgcc/enable-execute-stack.c links to an absolute path /jenkins_builder/workspace/GLLO_1.0.5-Toolchain-Linux64/yocto_build/tmp/work-shared/gcc-4.7.2-r20/gcc-4.7.2/libgcc/enable-execute-stack-empty.c
Warning: file /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/i586-poky-linux-uclibc/usr/src/debug/libgcc/4.7.2-r20/build/libgcc/md-unwind-support.h links to an absolute path /jenkins_builder/workspace/GLLO_1.0.5-Toolchain-Linux64/yocto_build/tmp/work-shared/gcc-4.7.2-r20/gcc-4.7.2/libgcc/config/i386/linux-unwind.h
Setting it up.../tmp/tmp.N08iurxII6/relocate_sdk.sh /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/relocate_sdk.sh
SDK could not be set up. Relocate script failed. Abort!
find: invalid mode '+111'
i found this solution for the "find: invalid mode '+111'" error when i run the install_script.sh
[root@localhost ~]# .arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/install_script.sh
Setting it up.../tmp/tmp.sZeLSYMvkD/relocate_sdk.sh /root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/relocate_sdk.sh
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/raw2flash.akita
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/raw2flash.borzoi
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/perl.real
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/raw2flash.terrier
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/flash2raw.terrier
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/python
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/python-config
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/flash2raw.borzoi
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/python2-config
link:/root/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0/i586/sysroots/x86_64-pokysdk-linux/usr/bin/flash2raw.akita
link:/root/.arduino1...
Pedro_M_Intel
Hi lewatoto,
I'm very sorry for the delay in my reply. I wanted to let you know that this issue has been fixed in the Arduino IDE 1.6.7.
Peter.
Pedro_M_Intel
Hello lewatoto,
This seems odd, I currently don't have Fedora installed, but let me some tests to see what I can find out.
Peter.
Pedro_M_Intel
Hi lewatoto,
Peter.
