Intel® Makers
9877 Discussions
Arduino Program getting hanged after using pulseIn() function.
GS4
I am using Intel Galileo Gen2 Board to display the distance measured by HC-SR04 ultrasonic module. I used the following code:
[Code]
const int TrigPin = 8;
const int EchoPin = 9;
float dist;
void setup()
Serial.begin(9600);
pinMode(13,OUTPUT_FAST);
pinMode(TrigPin, OUTPUT_FAST);
pinMode(EchoPin, INPUT_FAST);
void loop()
fastDigitalWrite(TrigPin, LOW);
delayMicroseconds(2);
fastDigitalWrite(TrigPin, HIGH);
delayMicroseconds(10);
dist =pulseIn(EchoPin, HIGH,5000) / 58.0;
Serial.print(dist);
Serial.println(" cm");
delay(100);
digitalWrite(13,HIGH);
delay(100);
digitalWrite(13,LOW);
//resetFunc();
[Code]@
The output is getting hanged after few readings. Any Suggestions? If I reprogram the process repeats.
FTinetti
Honored Contributor I
Hi GauthamKS,
There are several threads on this issue (I've not tested them, and I've not used this specific sensor), please take a look and let us know your results:
HTH,
Fernando.
Community Manager
Hi GauthamKS,
Do you have any more questions? Please let me know in order to assist you.
Have a nice day!
-Jose
