Intel® Makers
9880 Discussions
Arduino code does not start on board boot up - Galileo gen 2.0
Community Manager
My blinky code or any other code that I load on Galileo does not start on boot up.
Please can u tell me the process so that the code starts as soon as i power up my board.
Parth Desai
FTinetti
Honored Contributor I
Hi Parth,
You should start with a Linux image in an SD card, and load the code you want to run. Step-by-step guide for windows is at https://software.intel.com/en-us/get-started-galileo-windows-step1 IoT - Step 1: Make a bootable micro SD card | Intel® Software , I suggest the manual method.
Did you already upgraded the firmware? Actually, the whole process guide starts at https://software.intel.com/en-us/get-started-galileo-windows IoT - Getting Started with the Intel® Galileo Board on Windows* | Intel® Software for Windows, and it contains links to other OSs too.
HTH,
Fernando.
Community Manager
Hey Fernando,
I followed the exact steps mentioned on the website. I did upgrade the firmware too but the code does not load on boot up.
root@galileo:~# cat /etc/version
201606081532
This is the version I am using. I flashed the latest image from intel site on to the SD card manually.
Parth Desai
FTinetti
hmmm... maybe the card is not booting from the SD card... just in case, please send the output of the commands
df
ls -la /
If you don't have access to a Linux console in your Intel Galileo just let me know and I'll send a sketch to see the output of those commands.
Fernando.
Community Manager
That's the output of the commands you said
root@galileo:/# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 1668912 1361012 221756 86% /
devtmpfs 118248 0 118248 0% /dev
tmpfs 118440 0 118440 0% /dev/shm
tmpfs 118440 8536 109904 8% /run
tmpfs 118440 0 118440 0% /sys/fs/cgroup
tmpfs 118440 0 118440 0% /tmp
tmpfs 118440 12 118428 1% /var/volatile
/dev/mmcblk0p1 50412 2288 48124 5% /media/card
root@galileo:/# ls -la
total 84
drwxr-xr-x 23 root root 4096 Jan 11 17:27 .
drwxr-xr-x 23 root root 4096 Jan 11 17:27 ..
drwxr-xr-x 2 root root 4096 Jun 8 2016 bin
drwxr-xr-x 2 root root 4096 Jun 8 2016 boot
drwxr-xr-x 14 root root 4040 Jan 11 18:23 dev
drwxr-xr-x 89 root root 4096 May 12 2016 etc
drwxr-xr-x 4 root root 4096 Jun 8 2016 home
drwxr-xr-x 9 root root 4096 Jun 8 2016 lib
drwxr-xr-x 2 root root 4096 Jun 8 2016 lib32
drwx------ 2 root root 16384 Jun 9 2016 lost+found
drwxr-xr-x 3 root root 4096 Jun 8 2016 media
drwxr-xr-x 2 root root 4096 May 12 2016 mnt
lrwxrwxrwx 1 root root 25 May 12 2016 node_app_slot -> /home/root/.node_app_slot
drwxr-xr-x 4 root root 4096 Jun 8 2016 opt
dr-xr-xr-x 67 root root 0 Jan 1 2001 proc
drwxr-xr-x 12 root root 340 Jan 11 18:23 run
drwxr-xr-x 3 root root 4096 Jun 8 2016 sbin
drwxr-xr-x 2 root root 4096 Jan 11 17:27 sketch
dr-xr-xr-x 12 root root 0 Jan 1 2001 sys
drwxrwxrwt 8 root root 160 Jan 11 18:23 tmp
drwxr-xr-x 11 root root 4096 May 12 2016 usr
drwxr-xr-x 8 root root 4096 Jan 1 2001 var
drwxr-xr-x 3 root root 4096 Jun 8 2016 www
drwxr-xr-x 3 root root 4096 Jun 8 2016 wyliodrin
FTinetti
Everything seems to be fine.
Please run
rm -rf /sketch/*
ls -la /sketch
(should show only . and ..)
Then, load the sketch and after the IDE message of the sketch being successfully loaded please run
ls -la /sketch
(should show a file named sketch.elf)
In case you think the sketch is not running after restarting the card please send the sketch so maybe we can figure out what could be the problem.
HTH,
Fernando.
Community Manager
Hey Fernando,
I am able to run the blinky code on boot-up.
https://github.com/knolleary/pubsubclient.git GitHub - knolleary/pubsubclient: A client library for the Arduino Ethernet Shield that provides support for MQTT.
I am trying to run the example mqtt_basic from the examples. I have my version of code which is tweaked with a bit and can email you the same if you can provide me your email id.
Parth Desai
FTinetti
Hi Parth,
Loop wrote:
Hey Fernando,
Then, the problem "Arduino code does not start on board boot up - Galileo gen 2.0" is solved, I think.
Parth Desai
Then I think the problem es running that specific library... I suggest you open another thread for that specific problem.
Searching in the forum, there are several threads on mqtt, but I don't have enough time to follow them in deep, take a look at:
(and maybe there are other threads too).
HTH,
Fernando.
Community Manager
Thanks Fernando,
Will do open a new discussion,
Parth
FTinetti
Loop wrote:
Thanks Fernando,
Parth
You are welcome,
Fernando.
Community Manager
Hello Parth,
I'm glad Fernando could help you solve your issue.
Fernando, thank you very much for your contribution and assistance.
Andres
FTinetti
Hi Andrés,
You are welcome,
Fernando.
