Intel® Makers
9881 Discussions
Arduino examples for IoT on AWS
TVelt
I have the Edison Grove IoT Starter Kit powered by AWS and I can't find a single code example of connecting to the AWS IoT service via the Edison. The Grove shield and sensors are an excellent way to prototype quickly and there's probably over a 100 sensors that are available. I am a big fan of AWS IoT and was hoping to connect to AWS using the Arduino IDE but the examples in the docs are for C or node.js. Perhaps I am missing something in the online docs, but I'd be astonished if there isn't a single example showing how to use the grove kit on Arduino to AWS. Any and all help is appreciated.
BPani
Hello TJVelte,
Thanks for your interest in AWS IoT.
Unfortunately we don't have any support for Intel Arduino platform currently. Our Arduino SDK works only with Arduino Yun. As you have mentioned it has to be C or NodeJS SDK for Edison.
Adding support to Intel Edison Arduino platform is in our roadmaps.
Bhadri
AWS IoT
Community Manager
Hi TJVelte,
I've checked the following site: https://github.com/intel-iot-devkit/aws-iot-intel https://github.com/intel-iot-devkit/aws-iot-intel, and it seems that AWS IoT is not intended to be used through the Arduino IDE, that's why there aren't code examples about it. The only examples available are the ones you pointed, and they are for C and JavaScript. Anyhow, I recommend you to contact the AWS team, they might be able to help you since they are the ones that supports this service: https://forums.aws.amazon.com/index.jspa https://forums.aws.amazon.com/index.jspa
Diego
BPani
Hello TJVelte,
Bhadri
AWS IoT
