Hi , I want to upload the arduino *.elf file by manual, just use the compile function of arduino ide .
1. What file need i upload to sketch folder ? "Blink.ino.elf " ? (such as Blink example) , because when i click the verify button, this file will generate .
2. And what operation need i do ? Rename the "Blink.ino.elf" to "sketch.elf" ? Because the format of this two file is different .
3. And what operation need i do to execute it ? If i did the order "./sketch.elf " , there is a error "-sh: ./sketch.elf : no such file or directory "
best regards
Hi Candice555,
Thanks for reaching out.
I remember that another user asked a similar question some time ago, but using the Edison board, he was suggested to follow these steps:
- Move the .elf file to /sketch using WinSCP, just like you did.
- Open PuTTY and connect to the Edison through SSH.
- Once you have access to the Edison's console, go to the directory /sketch and write the following command to give executable permissions to the file: chmod +x sketch.elf
- Then run the sketch with this command: ./sketch.elf foo bar &. Your sketch should run now.
I suggest you to try it and let me know if you have any questions. Here you can find more details about that discussion: /message/472202# 472202 Upload Arduino Sketch to Edison Arduino Wirelessly using Wifi.
Hope you find this information useful.
-Yermi A.
Hi Candice555,
-Yermi A.
Hi -Yermi A ,
I am appreciate you for you help.
This topic you mentioned i have seen it yet. But when i did the fourth step the error "-sh: ./sketch.elf : no such file or directory" occured. The sketch did not run.
By the way , whether i need upload the "Blink.ino.elf" (such as the blink example) file to the /sketch or not , or other file ? And i need to rename this "Blink.ino.elf" to "sketch.elf" is it right ?
best regards
Hi Candice,
It is not necessary to rename the file, but you can if you prefer. Please make sure you are copying the .elf file located at …%temp%\arduino_build_, and use the .elf file name to run the sketch ./ foo bar &
-Yermi A.
