Community
cancel
Showing results for
Search instead for
Did you mean:
Arduino upload never finish
I'm running Arduino 1.6.6 with Edison board on windows 8. When uploading the code to the board, it's stuck at this point forever.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
I also updated Edison with the latest image through phone flash tool lite.
How do I resolve this issue?
Carlos_M_Intel
Hi ckanthap,
Have you tried to delete the files in /sketch using the Terminal Console?
Are you selecting the right board and port in the IDE?
Did you have problems while installing the boards with the Boards Manager on the IDE?
Which sketch are you trying to upload? The Blink sketch?
Have you tried with different ports and USB cables?
Charlie
Thank you! I tried a Edison virtual com port (versus USB serial port) and it works.
