Intel® Makers
9881 Discussions
Attempting to dual boot ubuntu
JVanB
Valued Contributor II
I tried following linuxium's instructions http://www.linuxium.com.au/how-tos/dualbootingubuntuandwindowsonthecs125intelcomputestickstk1aw32sc Dual booting Ubuntu and Windows on the CS125 Intel Compute Stick (STK1AW32SC) - Linuxium to dual boot Windows 10 x64 and ubuntu on a STK1AW32SC but eventually ran into the low graphics issue http://askubuntu.com/questions/141606/how-to-fix-the-system-is-running-in-low-graphics-mode-error xorg - How to fix "The system is running in low-graphics mode" error? - Ask Ubuntu which seems to be a software issue that prevents X windows from loading and has many potential causes.
The Windows 10 x64 went pretty much OK, although the instructions about wiping out all the disk partitions might have been more specific about really wiping every last one out, no matter how scary it looks, and installation and updates might have gone more smoothly if I had known about the recommendation to remove the Micro SD card beforehand.
At this point I could run ubuntu in live DVD (actually live USB) mode, and sound and WiFi worked, although that SanDisk Ultra PLUS microSDXC UHS-1 64 GB card didn't seem to be visible to ubuntu. My bad, as SanDisk 64 GB cards were already called out as not working in ubuntu. On installing ubuntu, I got to the stage where you update and upgrade ubuntu but I didn't see the dialog box at 6:22 of https://www.youtube.com/watch?v=UQPCYwz-PK0&feature=youtu.be Dual booting on the CS125 Intel Compute Stick (STK1AW32SC) - YouTube and on reboot I got to the low graphics screen. Oh, I guess I got through upgrading of the kernel and the reboot at 6:53 was where things went south. So there are two ways forward that I can imagine: either to figure out what was different in my procedure from linuxium's that worked or to be able to perform diagnostics from the from live DVD mode or recovery console so I could get help to fix the problem.
The first path seems the more promising. Differences were that I had a newer BIOS than the date of the video, having upgraded about two weeks ago, that I used the https://goo.gl/B1L3pj zesty-desktop-alpha-131216-linuxium.iso - Google Drive linked to on linuxium's web page, and that rufus complained about missing a couple of files that it went out on the internet and downloaded for me. This last difference may be the problem in that if the staging directory with rufus and the ISO already contains the rufus files subdirectory, rufus will silenty use those files, so the ones it downloaded for me may be different from the ones used in the video.
As for the second path, I had an undergraduate over yesterday and even he couldn't figure out how, in recovery console mode, to change the graphics mode so the leftmost 128 pixels didn't get chopped off, connect to internet via the WiFi so all the suggestions about using apt-get could be tried, or to save the output seen on the recovery console so that I could post it back to kind people who were trying to help me.
Community Manager
Hello Repeat%20Offender ,
Thank you for posting in our Intel Communities.
I would like to let you know this configuration is not officially supported by us, you can test it for sure, but it would be done under your own responsibility/risk.
My recommendation would be to check if other users here have performed this and can assist you with the inquiry.
Hope you can get this solved, if you can, it would be great to report it for future questions from other users
Esteban C
linuxium
New Contributor III
How much space did you allocate to the Ubuntu partition (see 5:35 in the video)? If you boot from the LiveUSB how big is the Ubuntu partition currently and how full is it (c.f. 'df' command)?
JVanB
I only allocated 8.5 GB; later I read that I was supposed to allocate at least 8.6 GB. But that was only a part of the problem: since things weren't going well I tried installing version 16.10 and only later did I read on https://liliputing.com/2015/07/install-ubuntu-14-04-lts-on-the-2gb-intel-compute-stick.html https://liliputing.com/2015/07/install-ubuntu-14-04-lts-on-the-2gb-intel-compute-stick.html that I should have used efibootmgr to clean up the boot entries. I got to a setup where I couldn't boot anything and ended up reinstalling Windows x64 from scratch.
So today I tried again allocating 10.0 GB with the version https://goo.gl/6M3xwO zesty-desktop-alpha-281216-linuxium.iso - Google Drive and this time I skipped upgrading the kernel as it seemed to already have the latest kernel according to uname -a. Unfortunately after I rebooted without the USB stick inserted, I couldn't boot to anything successfully. The menu shows only ubuntu and booting to that results in no bootable device detected. So I seem to have hosed my Compute Stick once again and am hoping for guidance on making forward progress without reinstalling Windows. If I use the Windows recovery disk (actually USB stick) that I made will I at least be able to avoid the lengthy Windows update part of reinstallation?
EDIT: I tried 32-bit Windows instead of 64-bit Windows at the BIOS screen and it successfully booted to ubuntu. Still can't see how to boot to Windows. Selecting Windows boot manager at the GRUB screen only cycles back to the GRUB screen. Playing a 4k video in full screen mode in firefox now doesn't lock up the system, but it makes it unstable. For example switching back to normal window size creates a situation where moving the mouse cursor around the screen leaves behind a trail of cursors dancing happily that only go away when a window is moved over them.
linuxium
New Contributor III
When you re-installed Windows X64 was the BIOS was set to 64-bit? And also when you then installed my Zesty ISO it was still set to 64-bit? If so then it sounds like the NVRAM and ESP are out of sync but this is not a major drama. All you need to do is boot from the Ubuntu LiveUSB again and fix it using the 'efibootmgr' command. However if you have subsequently changed the BIOS to 32-bit and Ubuntu boots it sounds like Ubuntu installed as 32-bit so that doesn't make sense. Can you set the BIOS back to 64-bit and re-install Ubuntu from the ISO? This time when asked the type of installation, select the option to re-install Ubuntu (rather than upgrade or erase disk and install Ubuntu). If having re-installed Ubuntu as 64-bit and there is nothing to boot after the installation reboot, then here are the steps to fix the NVRAM:
1. Start with the ICS switched off.
2. Connect your LiveCB USB.
3. Power on the ICS and press F10 and boot from the USB.
4. Open a terminal windows and enter:
sudo su -
# if efibootmgr isn't already installed enter:
apt-get install efibootmgr
5. Remove any boot entries that may have been created through the earlier install or attempts to get things working by entering:
for BOOTENTRY in 0 1 2 3 4 5 6 7 8 9
do
efibootmgr -b ${BOOTENTRY} -B
done
6. Create an Ubuntu boot entry by entering:
efibootmgr -c -d /dev/mmcblk0 -p 1 -l \\EFI\\ubuntu\\grubx64.efi -L Ubuntu
7. Reboot and press F10 and boot from the newly created Ubuntu entry.
JVanB
I was pretty sure that the BIOS was set to boot 64-bit Windows at all times, so I tried the loop you offered. Now 32-bit Windows in the menu boots to no bootable device detected, Android boots to Windows, and 64-bit Windows booted once to Windows and once to no splash screen. So I guess I should have tried Android before wiping out the boot entries with efibootmgr.
linuxium
New Contributor III
So now you have removed the boot entries with 'efibootmgr' I suggest re-installing Ubuntu from the LiveUSB (select 're-install Ubuntu' rather than 'upgrade' or 'erase disk and install Ubuntu' which given the option in the installater). And before doing so make sure BIOS is set at 64-bit. With a clean install of Ubuntu the GRUB menu should be the first thing you see when booting and this will have options to boot either Ubuntu or Windows.
JVanB
I tried reinstalling ubuntu. Then I did the update and upgrade, then shut down the Stick, removed the USB drive and held the power button for 3 seconds (trying to access BIOS during a normal boot never works for me; I always have to hold the power button for 3 seconds), hit , chose Windows 32-bit, with the result "A bootable device has not been detected"
Power off, then tried . The only choice was UEFI : ubuntu : PART 1 : OS Bootloader. After choosing it got into the GRUB menu and booted into ubuntu.
Shut down and tried normal boot. Again arrived at GRUB. At this point choosing Windows Boot Manager (on /dev/mmcblk0p2) simply cycles back to the GRUB menu, so I booted to ubuntu.
Shut down, the tried and chose Windows 32-bit, which brought me back to GRUB again. Windows &c still cycles, so I booted to ubuntu.
Shut down and tried . Again, the only choice was UEFI : ubuntu : PART 1 : OS Bootloader and again arrived at GRUB. Windows &c cycles so I booted to ubuntu.
Shut down and performed a normal boot. Got to GRUB. Windows &c cycles, so I booted to ubuntu.
Shut down and tried and chose Android, this time I got A bootable device has not been detected.
Power off, then tried . The only choice was UEFI : ubuntu : PART 1 : OS Bootloader and again arrived at GRUB. Windows &c cycles so I booted to ubuntu.
Shut down and performed a normal boot and was back at the GRUB menu...
So now I can boot to ubuntu, even most of the time, but not Windows.
linuxium
New Contributor III
I'm not sure why you first changed the BIOS back to Windows 32-bit after installing Ubuntu. Because you only need to choose the 64-bit bootloader in the BIOS at the beginning and then install Windows followed by Ubuntu. After that when you power-on you will get the GRUB menu from which you can chose to boot either Windows or Ubuntu.
At this point it is probably faster to start again rather than diagnose and try to fix your current install. I recommend you just install the two operating systems and confirm dual-booting works and then fix issues like missing drivers and performing updates and upgrades. Start by removing all USBs, SD cards etc and boot the stick into the BIOS and make sure the bootloader is set as 64-bit. Then insert your 'Windows 10 x64' bootable USB and install Windows (deleting all partitions when prompted to do so). During the installation process do not connect to the internet (either wirelessly or using a USB ethernet), use a local account for the install and do not attempt to perform any updates. Once Windows has installed remove the USB and confirm that you can boot in and out of Windows. Then boot into Windows again and reduce the size of the C: drive by 10GB to create space for the Ubuntu install. Next insert your 'Zesty ISO' bootable USB and install Ubuntu using the 'Install Ubuntu alongside Windows Boot Manager' option during the installation. Again during the installation process do not connect to the internet (either wirelessly or using a USB ethernet) and do not attempt to perform any updates or upgrades. Once Ubuntu has installed remove the USB and confirm that you can boot in and out of Ubuntu using the GRUB menu. Then confirm that you can boot in and out of Windows using the GRUB menu. Having successfully installed and dual-booted Windows and Ubuntu your Windows install will be missing key drivers like audio and both will need updates to be applied. Connecting to the internet is now okay to do. To 'fix' Windows it is best to download and use the 'Intel Driver Update Utility' from Intel's website and Ubuntu can be updated using 'sudo apt-get update && sudo apt-get upgrade' as usual. You can see further instructions how to do this in the video. After that everything should work.
JVanB
Well, I can sort of dual boot at this time. If I'm in ubuntu I can boot to Windows via
sudo efibootmgr -o 0002,0000
And then setting the BIOS to boot to 64-bit Windows. Unfortunately
sudo efibootmgr -n 2
Didn't do the trick. To get back to ubuntu, I boot from the Live USB and enter
sudo efibootmgr -o 0000,0002
Then shutdown, remove the Live USB, and reboot. The BIOS seems to get switched to 32-bit Windows at some point along the way. Gary Newell's pages, for example https://www.lifewire.com/change-the-efi-boot-order-efibootmgr-4028027 How To Change The EFI Boot Order With efibootmgr and http://www.everydaylinuxuser.com/2016/04/how-to-remove-ubuntu-from-computer-dual.html How To Remove Ubuntu From A Computer Dual Booting With Windows 10 (UEFI only) " Everyday Linux User were very useful for figuring this out.
This may be a bug in the BIOS in that in either case I only see one boot entry: either
UEFI : Ubuntu : PART 1 : OS Bootloader
or
UEFI : Windows Boot Manager : PART 1 : OS Bootloader
Both in the screen and the screen. Or do you think it could have been operator error in that I might have installed one OS in EFI mode and the other in legacy mode? But if I did that, would both boot entries be prefaced by UEFI? How could I make sure, for each OS, that I was installing in EFI mode?
I may yet reinstall all that jazz once again, but I would like no know whether this is a BIOS bug or not first and I have at least marginal functionality for now.
linuxium
New Contributor III
The Intel Compute Stick only seems to show one UEFI boot option from the NVRAM. This shouldn't matter though because as long as you set it to the Ubuntu one, that should boot GRUB from where you can then choose either Ubuntu or Windows. However you have said that this doesn't work when trying to boot Windows. Given that Windows is installed and bootable I would boot your installed Ubuntu and then enter 'sudo update-grub' to re-create your GRUB menu. Then reboot and see if booting the Windows option from GRUB works. Also given that your EFI partition seems okay, have you tried using the built-in EFI shell? First you have to (may have to) enable it from the F2 BIOS boot menu and then you can select 'UEFI: Build-in EFI Shell' option as the F10 boot device. There are plenty of guides out there on the web but it will be along the lines of entering 'fs0:' to start and then 'ls' to see the directory structure with 'cd' to change and finally running the various 'grubx64.efi/shimx64.efi' typically in \EFI\ubuntu\ or \EFI\BOOT\ for Ubuntu and 'bootmgfw.efi' etc in \EFI\Microsoft\Boot\ for Windows.
JVanB
I had some time to try playing around with linux again today. sudo update-grub didn't help: choosing the Windows boot manager entry still just cycles back to the GRUB menu.
I was able to get to the EFI shell as you described, but doing anything constructive from there is beyond my capabilities at this point. I found a little tutorial https://software.intel.com/en-us/articles/efi-shells-and-scripting EFI Shells and Scripting | Intel® Software but it didn't help that much because some commands such as bcfg didn't seem to be available on the STK1AW32SC, not to mention that the results of any command would scroll off the screen and there is nothing like mode to get a bigger effective terminal or more to stop the scrolling.
So that was kind of a bust, but I more clearly worked out the sequence I need to dual boot currently:
From Windows, with the power off, insert the Live USB
Turn the power on
From the menu select boot to USB
At the GRUB menu select try Ubuntu without installing
After ubuntu boots, hit --T to start the terminal, then enter the commands
sudo efibootmgr -o 0003,0000,0002
sudo poweroff
The first command assumed 0003 was the USB, 0000 was ubuntu, and 0002 was Windows. The second command was necessary because ubuntu boots into the wrong video mode and the icon you need to shut down is not visible.
Then remove the USB
Turn the power on
From the menu select Windows 32-bit
Now the Stick boots to ubuntu.
From ubuntu,
Turn the power on
Choose ubuntu from the GRUB menu
Log in to ubuntu, then hit --T to start the terminal, then enter the commands
sudo poweroff
Turn the power on
From the menu select Windows 64-bit
Now the Compute Stick boots to Windows.
Kind of an ugly sequence; it would be nice if one of the menus in BIOS or GRUB worked, but that's nonsupported software for you I guess.
linuxium
New Contributor III
This has clarified what the problem is: your installed Ubuntu is using 32-bit GRUB rather than 64-bit GRUB. That is easy to fix as you just need to install 64-bit GRUB when running your installed Ubuntu i.e. not the one on USB. In a terminal enter 'sudo apt-get install grub2-common grub-efi-amd64-signed grub-efi-amd64-bin grub-efi-amd64 shim shim-signed' and then (just to be sure) enter 'sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --boot-directory=/boot --bootloader-id=ubuntu' and then reboot, F2 to swap BIOS back to 64-bit, and then boot to GRUB where both Windows and Ubuntu should work.
JVanB
Nice haruspicy and incantation! Indeed GRUB works appropriately now. There would be no chance for users such as myself to get ubuntu up and running on the STK1AW32SC without your efforts. Sound and WiFi are not problematic. Which microSD card should I get to replace my 64 GB SanDisk card that ubuntu can't see?
linuxium
New Contributor III
Here's a post I did about micro SD cards a while ago: http://linuxiumcomau.blogspot.com.au/2016/03/performance-testing-microsd-cards.html linuxium.com.au: Performance testing microSD cards ... I'm currently using my 32GB Samsung PRO cards with Ubuntu on the STK1AW32SC as my Sandisks cards do not work.
JVanB
An update on some of the ubuntu issues:
Issue 1: ubuntu can't see my SanDisk Ultra Plus microSDXC UHS-1 65 GB card
Solution: I tried a Samsung EVO Plus 64 GB microSDXC UHS-1 card; unfortunately ubuntu couldn't see that either.
Issue 2: ubuntu mungs up the system clock
Solution: In terminal, enter the command
sudo hwclock --systohc -- localtime
Problem solved. Now, some Linux geeks might complain that this is an affront to the almighty LT & RMS themselves because I might have to reset the time manually on the switch to DST, but I say just get in line behind my wristwatch, answering machine, and stovetop.
Issue 3: ubuntu requires hard reset via power switch after watching YouTube videos @1080p for a couple of seconds
Solution: I tried getting https://01.org/linuxgraphics/downloads/intel-graphics-update-tool-linux-os-v2.0.3 https://01.org/linuxgraphics/downloads/intel-graphics-update-tool-linux-os-v2.0.3 and after downloading it, I could navigate to the downloads directory in terminal and enter the command
sudo dpkg -i intel-graphics-update-tool_2.0.3_amd64.deb
Then I got an error message saying that it needed fonts-ancient-scripts; maybe ubuntu needed to sing 3 lullabies in an ancient tongue or something, but in any case I tried
sudo apt-get install fonts-ancient-scripts
and then the dpkg command went through OK. However, I don't think this achieved anything; just installed the update tool. Upon attempting to run the tool, however, I got an error about the wrong version, so I don't think the above procedure helped my cause at all.
Somewhere I made a note that I was supposed to go to System Settings->Software and Updates->Additional Drivers and also to System Settings->Displays.
In the first instance I concluded that the thing to do was to type
unity-control-center
from the terminal and then to navigate to Software and Updates, then Additional Drivers, and there I checked "Using Processor microcode firmware for Intel CPUs" or something like that. This step did in fact help in that, although I still seemed to lack the hardware acceleration necessary to stream videos at any resolution above 720p, at least firefox wasn't locking up my Compute Stick any more. I never did figure out that note about System Settings->Displays, though.
Issue 4: Because ubuntu
Solution: Go outside for long walks and attempt to get more exercise in the meager sunshine available this time of year.
Issue 5: The Dash always displays the empty set no matter what
Solution: From the terminal, type
desktop-file-validate /usr/share/applications/*.desktop
and it shows a lot of errors. However, I'm not really sure about how to fix them. It seems that there are a lot of things that can go wrong with the Dash and a lot of potential solutions. Rather than spend time messing around with this (to my mind) defective software, I launch applications by opening the Files application, then navigating to /usr/share/applications, then double-clicking on the desired application. Is there any way to navigate upward in Files with the mouse? I always end up entering /usr/share via the keyboard.
Issue 6: Neither apt-get nor Synaptic work until about 15-20 minutes after bootup
Solution: In the terminal, type
sudo system-ctl disable apt-daily.service
sudo system-ctl disable apt-daily.timer
At least you can disable these automatic updates that ubuntu enables by default that can knock over your Compute Stick and otherwise cripple your productivity, unlike what is the case in Windows 10.
Issue 7: Hello, world doesn't compile or doesn't link or doesn't run correctly
Solution: This is a complicated problem in itself that I will leave for another post.
Ronny_G_Intel
Community Manager
Hi Repeat%20Offender,
This is a great post, really good source of information for customers trying to do anything similar, thanks for sharing.
I work for Intel Customer Support and I just wanted to let you know that if you don't see anybody from Intel jumping in, it is because we are officially limited to what we have validated
See here for more information: http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005899.html Supported Operating Systems for Intel® Compute Stick
Thanks again for making all this information available for other customers to try and I would encourage other community members to share their findings.
Ronny G
JVanB
Thanks for the encouragement. Today I was trying to find out why a Hello, world program wasn't working correctly. I had taken http://www.paulgriffiths.net/program/c/srcs/helloxsrc.html HTML output off the web and while it compiled OK, running the resulting executable produced an X window that was seemingly invisible. Drilling down I found that it had used a variable border_width uninitialized. As a consequence the border width of the X window was some unrealistic value. Setting border_width = 0 before it was used created a normal-looking window! Who would have thought that a program you downloaded off the web would have a bug What I get for not always using -Wall. Maybe I can find out why the other Hello, world examples I downloaded didn't work now.
