Intel® Makers
9872 Discussions
Audio Capture at 96Khz 8slot on I2S
Tigi_T_Intel
I would want to record 8 slot 96khz audio from I2S port of Intel Joule.
Can I know whether this configuration is supported in SW and Driver.
Can you please give me the required configurations to do the same...
Thanks alot.
Tigi
Community Manager
Tigi,
Look at the datasheet. There you will see what I2S/PCM formats are supported.
You won't be able to capture more than two I2S channels at any sampling rate.
The hardware doesn't have that capability.
Stu
Community Manager
Hi Tigi,
Thank you for contacting us.
We want to let you know that we are investigating your case. We'll get back to you once I have some more updates.
Kind regards,
-Pablo
Community Manager
Tigi,
Stu
Community Manager
Hi Tigi,
Stu is right (thank you for your post Stu), check the datasheet here: http://www.intel.com/content/dam/support/us/en/documents/joule-products/intel-joule-module-datasheet... http://www.intel.com/content/dam/support/us/en/documents/joule-products/intel-joule-module-datasheet.... Go to page 10, under "Intel Joule feature summary", and you can also check section 11.1.1 (I2S Specifications).
-Pablo
