Community
cancel
Showing results for
Search instead for
Did you mean:
ADixi1
Audio and images using Yowsup
Jump to solution
Hello all,
I am trying to send an audio file and a picture to my whatsapp account on intel edison using yowsup. Can somebody please provide me as to how to do this ?I am successful in sending a text message to whatsapp but how to send an audio n image file ?
I got this link but I am unable to understand how to go about it.Kindly somebody help.
https://github.com/tgalal/yowsup/issues/617 Sending Audio with yowsup-cli · Issue # 617 · tgalal/yowsup · GitHub
Pedro_M_Intel
Hello Akanksha,
I was installing Yowsup to see If could run some tests. During the process threw an error that mentioned that jpeg is not installed and that it could be disabled from the installation.
Did you install jpeg? Or, did you disable it on the installation? I mean, this might be a cause of issues when trying to send images.
I found https://github.com/tgalal/yowsup/wiki/Upload-and-send-Media Upload and send Media on the Yowup github. Is this what you are looking for? I suggest you to check it out.
Also, since this is a third party application, you'd probably get a more accurate answer regarding its operation with the original author. You can contact them in https://github.com/tgalal/yowsup/issues Issues · tgalal/yowsup.
Peter.
Pedro_M_Intel
Hello Akanksha,
Peter.
ADixi1
Hi Peter!
I went through the links you suggested but I am unable to understand the yowsup architecture as I am new to it. I understand that I need to request a URL to upload my data and then further send the msg. For which I need to make some modifications to my Yowsup-cli library (correct me if wrong!!). But i am not very sure where to add my layer.py and stack.py files and how to execute them to enable my board sending msgs.
Pedro_M_Intel
Unfortunately I'm not familiar with the library and as I explained above I couldn't install it due to an error about jpeg... so I was not able to test it. My best suggestion for you would be to contact the author of this library in the link I suggested before, they might help you with the architecture and the changes needed to use this library.
Peter.
