Intel® Makers
9881 Discussions
Audio on Intel Edison
TGree15
Would anyone be able to help me with my project? I would like to perform the following with my edison chip and its arduino breakout board:
1. Store audio files on an SD card that is inserted into the board.
2. Using the edison as an audio player, I would like to output a varying voltage source for an LED light board, connected to one of the outputs on the board.
3. Eventually, I would like to be able to download new audio files to the SD card, using WiFi.
Pablo_M_Intel
Hi ClearTech,
There are some guides from Intel and all over the Internet that you might find useful. First, check the http://download.intel.com/support/edison/sb/edisonaudio_332434001.pdf Edison Audio Setup Guide for general information, probably you'll need to check this guide more than once. To play music with your Intel Edison you can take a look at this guide http://www.instructables.com/id/Playing-music-with-your-Intel-Edison/ http://www.instructables.com/id/Playing-music-with-your-Intel-Edison/, it consists in playing music via external speaker using a USB sound card. There's also this guide to play audio via Bluetooth using A2DP, https://software.intel.com/en-us/articles/play-audio-from-your-intel-edison-via-bluetooth-using-adva... https://software.intel.com/en-us/articles/play-audio-from-your-intel-edison-via-bluetooth-using-adva.... About managing files and data from an SD card with your Edison, there's a lot of information available in the Community, here's something for you to start /thread/55914 https://communities.intel.com/thread/55914.
Pablo
Pablo_M_Intel
Hi ClearTech,
Pablo
TGree15
That all makes sense so far. I can establish bluetooth comms and WiFi. When I get to this stage on the instructables page however, it doesn't seem to work like it should I'm sure I'm missing something:
Step 3: Installing Packages
Package Manager:
You need to configure your opkg repository to include the following lines:
src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all src/gz edison http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all src/gz core2-32 http://repo.opkg.net/edison/repo/all
Do so by typing:
vi /etc/opkg/base-feeds.conf
By typing this above line in, it doesn't seem to automatically configure my opkg repository. Do I need to follow the path and manually enter all of the opkg lines? My WiFi connection is good, so that doesn't seem to be the problem.
Pablo_M_Intel
Hi ClearTech,
Yes, you'll need to enter those lines by yourself. The command vi /etc/opkg/base-feeds.conf creates or opens (in case it already exists) a file called base-feeds.conf in the /etc/opkg path that you can then edit (vi is a text editor). If you're not sure how to use VI, check the following guide https://www.cs.colostate.edu/helpdocs/vi.html https://www.cs.colostate.edu/helpdocs/vi.html.
Pablo
