Community
cancel
Showing results for
Search instead for
Did you mean:
PDe_P
Auto-Start a Arduino sketch at boot on Arduino breakout board
Jump to solution
I have a problem running a sketch on this board after uploading, the sketch will not run automatically when the Edison powers up.
I used de fix described in the book "Getting Started with the Intel Edison" basically using the program WinSCP to change the Properties
of the file sketch.elf X-checkmarks permissions set for Owner, Group and Others.
After reboot, using the PWR button, the sketch is not starting any more. What need to be done more?
Carlos_M_Intel
Hi Paul,
There is a known bug with this feature while using the latest image version.
Fortunately, there is a workaround:
Let us know if this works for you.
Charlie
EstebanA_C_Intel
Hello:
I would like to inform you that this thread is going to be re routed to the correct Forum , they are going to be providing you with an answer for your inquiry.
Esteban C
Carlos_M_Intel
Hi Paul,
Charlie
PDe_P
Hi Charlie,
Thanks for Your responce, but before Your answer, I found a working solution on the net which can be usefull for others:
https://software.intel.com/en-us/blogs/2015/08/01/procedure-to-autostart-the-arduino-sketch-on-ediso... Procedure to Autostart the Arduino Sketch on Edison | Intel® Developer Zone
This is working for me , so I wait for a new image release where this problem is solved.
Paul.
