Community
cancel
Showing results for
Search instead for
Did you mean:
BWill15
New Contributor II
Autocomplete / intellisense mraa library
Jump to solution
How do i get autocompletion or intellisense in PyCharm like this for the https://github.com/intel-iot-devkit/mraa mraa library? I tried to add mraa in File, Settings, Project Interpreter.
Do i have to install Eclipse instead?
Pedro_M_Intel
Hello BrechtW,
I'm not familiar with PyCharm, so I'm not sure if third party libraries can use this feature. My best suggestion is that you reach out to their team so they can provide you a more accurate answer on how to do it or if it is even possible. So you should post your question in https://www.jetbrains.com/devnet/pycharm/ JetBrains :: PyCharm Dashboard.
Peter.
Pedro_M_Intel
Hello BrechtW,
Peter.
Pedro_M_Intel
It's great to hear that you found a way to make it work, if you ever encounter any other issues while using your board, don't hesitate to come back to the community.
Peter.
BWill15
New Contributor II
PyCharm deducts autocompletion from code i've already written. So it doesn't work to a full extent.
I noticed PyCharm uses https://pypi.python.org/pypi https://pypi.python.org/pypi for autocompletion and mraa isn't in the list.
