Hi everyone
I'm doing home automation project with intel edison. I want to blink led using azure. But I did not connect. Can somebody help me please?
Hi mekatronik,
Could you please tell us if you're following any guide? Like this one https://software.intel.com/en-us/articles/intel-edison-board-microsoft-azure-iot-suite-setup https://software.intel.com/en-us/articles/intel-edison-board-microsoft-azure-iot-suite-setup? If so, in which step are you getting stuck? We would like to know this so we can help you further.
PabloM_Intel
Hi mekatronik,
PabloM_Intel
I can not do this method. I used putty for azure settings but I can not run the specified code
Hi mekatronik,
Which image are you using? If you're not sure how to get this information, enter the next command in your board: configure_edison --version. What do you get? Regarding the Azure guide for Intel Edison, where are you getting stuck? Which code are you referring to?
PabloM_Intel
Yocto version 2.0 I've tried it"https://software.intel.com/en-us/articles/intel-edison-board-microsoft-azure-iot-suite-setup IoT - Setting up the Intel® Edison Board with the Microsoft Azure IoT Suite | Intel® Developer Zone". But it does not proceed in this way. I get an error. In fact, I want to blink led application over the phone. And safely.
Hi mekatronik,
Have you tried this using the latest Yocto image? I would suggest you to run this same guide https://software.intel.com/en-us/articles/intel-edison-board-microsoft-azure-iot-suite-setup https://software.intel.com/en-us/articles/intel-edison-board-microsoft-azure-iot-suite-setup but using the latest software. You can download it from here https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads.
Could you please share a picture of the error?
PabloM_Intel
