Community
cancel
Showing results for
Search instead for
Did you mean:
ABasu1
Innovator
Azure app service with Intel Edison
Hi all,
I wanted to read data from an azure app service's easy tables usign REST API. Before I did the same using Azure Mobile Services and my code was this
if (client.connect(server, 80)) {
// POST URI sprintf(buffer, "GET /tables/%s HTTP/1.1", table_name);
client.println(buffer);
// Host header
sprintf(buffer, "Host: %s", server);
// Azure Mobile Services application key
sprintf(buffer, "X-ZUMO-APPLICATION: %s", ams_key);
// JSON content type
client.println("Content-Type: application/json");
client.print("Content-Length: ");
client.println(strlen(buffer));
// End of headers
client.println();
// Request body
where server name was "genesis-iot-control.azure-mobile.net";
but now authentication has changed and mobile service has been replaced by app service. How can I access them using REST API on Intel Edison?
I had followed this http://stackoverflow.com/questions/36836566/post-for-azure-mobile-web-app-working-from-arduino lead but with no solutions.
Any kind of help is appreciated.
Community Manager
Hi Avirup171,
When the authentication changed and the mobile service was replaced by an app service, do you see an error? There is information about the common error codes and information about API authorization here https://github.com/enableiot/iotkit-api/wiki/Api-Home https://github.com/enableiot/iotkit-api/wiki/Api-Home .
I also found this link which has lots of useful information on REST API. Take a look at http://www.programmableweb.com/news/how-to-add-restful-api-to-intel-edison-and-work-it/sponsored-con... http://www.programmableweb.com/news/how-to-add-restful-api-to-intel-edison-and-work-it/sponsored-con... and let me know if you found this helpful.
-Sergio
ABasu1
Innovator
Can you provide me any sample? In the link posted in my query, a method has been suggested but not receiving anything.
Community Manager
Community Manager
Hi Avirup171,
Do you still need help with this thread, were you able to read data from the Azure App Service?
-Sergio
