Intel® Makers
9880 Discussions
B0100000063f694 error
ENeag
I have a problem: when I try to connect to the Gallileo board using a usb cable Putty gives me this error "/message/324466# 324466 B0100000063f694" or it just freezes.But it also happened that the computer would say it doesn't recognize the USB device because it had problems with it in the past.Any ideas?
Pedro_M_Intel
Hello EduardNeagoe,
Are you trying to connect to your board's Linux console through USB? If so, then you will not be able to do so. The micro-USB port was designed to be used with the Arduino IDE for programming and for the IDE's serial monitor.
If you want to connect to the Linux console of your board, you should use an FTDI cable.
Regarding the issue that you mention about the USB not being recognized, have you installed the Galileo's driver?
If you haven't, you will find it here:
https://downloadcenter.intel.com/download/24748/Intel-Galileo-Firmware-and-Drivers-1-0-4 Download Intel® Galileo Firmware and Drivers 1.0.4
Also, have you seen the following guide?
https://software.intel.com/en-us/installing-drivers-and-updating-firmware-for-arduino-windows IoT - Installing drivers and updating firmware for Arduino on a system with Windows* | Intel® Developer Zone
Peter.
Pedro_M_Intel
Hello EduardNeagoe,
Peter.
ENeag
That's what I'm trying to do, to connect through the micro-USB to use Eclipse C++ IDE.Now windows recognizes the port but putty just freezes.I'm using putty to find out the board's IP so I can use this IP in Eclipse as target.
Pedro_M_Intel
As I mentioned in my previous post, you won't be able to connect to your Galileo's Linux terminal using its micro-USB port. In order to connect to the board's Linux, you have to use a serial cable. In the following document, you will find which is used with Galileo Gen1 and Gen2:
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000006343.html?w... Console Serial Cables for Boards and Kits
You will need to use these cables otherwise you won't be able to get the board's IP. You should then follow this guide to connect to Linux:
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000006142.html How to Connect the Intel Galileo Board to Linux* for Boards and Kits
Peter.
